Car works great bud, nice and strong again.
Ill be back soon for the other work suggested.
Thanks again
Pete
So did he wave his magic wand and sort all yer niggley probs out for yer mate, if so what was the culprit ?
Glad yer a happy chappie now though :)
smithy
there were a few things needed looking at,
Conzult diagnostic
Timing was out,
1 o2 sensor is dead (put in loop untill i can afford replacements)
Air/fuel gauge interfering with o2 sensor
Tps setting was out
Throttle balance out
An electrical sendor replaced because my boost gauge sat in the middle on vacuum and no boost leaks found.
I also needed doing
PCV Valves installing
Spark plugs installing
Rad flush
2x new throttle body pipes replacing
And i have an advisory on Rear hicas bushes and front tension rod bushes as they are wearing out
Im glad its all sorted tho as it was really pissing me off, stalling all the time, running very rich and just being all round shite
Conzult diagnostic
Timing was out,
Tps setting was out
I also needed doing
Rad flush
the biggest mistake peeps make is playing with the base idle before checking other perimeters 1st imho
Geez had a few things to sort then :) All basic setting up stuff by the sounds of it though. I know you've been sooo frustrated lately trying to get it running right, trying everything under the sun. Sometimes it's so much easier to forget it and give it to a man who does what it says on the tin :D
Well done!
smithy
too true
i need to get down there sometime for a quick check up
just finding the time
only have weekends free
Cool Pete, sure was a few weird issues there, very difficult to resolve without a proffessional diagnostic to be fair so don`t feel too bad about your own efforts you had done ok concidering.
Jeff TT
