Power Door Locks
Hello all! Merry xmas and all that!!
I have a uk TT and I am wondering is there a fuse for the door locks? mine have stopped working and I dont have a door key just the key fob for the alarm which opens the doors! if there is no fuse any ideas why it stopped working?? cheers!
  • Replies 30
  • Views 1.9k
changed the battery in your fob?
No I havent mate, it does need changing? but when I lock doors from inside it doesent feel electric so no power I spose??
not that im aware of
Looks like im guna have to strip door down?? dont fancy that its to cold!
if its just the fob thats not working try changing the battery first, you can get them from tesco for £1
The wife has just left to go into town so will text her and see if she will get me one!
Changed the key fob batt but no change, the car batt has had it but it used to lock doors even if i go for a drive and lock doors at same time it still doesent feel theres any power in the lock?? surely there must be a fuse? or a relay or something?!
I have found the fuse in the drivers foot well which is fine so maybe its the batt as I need to use the jump starter to start it every morning!
Get a battery test done ! Think they do em for free at halfraud's
The batt has had it mate! the zed hardly goes anywhere now so spends alot of time doing nothing! and the clifford drains batt good and proper!
You need a door lock motor to be fitted on your drivers door to get an alarm to operate the central locking. There was no fob locking when the early cars were built I dont even know if remote locking was avalible on 95 on?
Allan
Allan
I can only open my doors with the alarm fob as I dont have a door key! so already fitted, maybe its knackered?? I can lock drivers door from inside and passenger door locks aswell makes all the noises but doesent feel right? could be a bent bar even??
Small plastic yellow bit is broken on the tumbler to the locking bar or has jumped off I would think
Allan
Allan
I have heard something about this yellow bit? If I get a chance today I best strip this door down and have a look for this yellow thing! Cheers!!
Here it is, its a right bar-steward to getattachment.php?attachmentid=43940&d=1221470909 to
Bargain! Cheers gruntpa64! I spose theres a bar that connects to the yellow bit??
The bar connects to the lock mechanism.If the drivers door has an aftermarket motor fitted for the alarm to work the central locking which i should imagine it does then the yellow clip breaking wont make a difference to your alarm opening the door.
Yep, what Jimmer says.
If locking the drivers door from inside, also locks the passenger door then the central locking system is fine and the fault is to do with your Aftermarket Alarm.
There will be an aftermarket door motor fitted that clamps to the standard central locking bars and is activated by the alarm. Take the door card of, and check the motor, its probbaly come loose where it clamps to the metal bar.
Door card has to come off anyway so will check everything you boys have said about it! So if the batts shag*ed would that make a difference? turn the key it just clicks so Im having to use jump starter every time. Even with jump starter on it does the same thing just clicks.
If the fob is u/s and the plastic clip is broken.then neather will open the door it will give the situation you have, as David said look to see if your passinger side operates when you turn the key in the drivers door.
Allan
Allan
I dont have a door key!!!!:(
Sorry miss read the first bit I thought you had the door key. Then you will find that the aftermarket motor link will be at fault (come undone/ broken) you really need to get a door key sorted somehow or your going to be up shit creek if the battery dies on the car. You will find youself crawling under the cat to get a lead on the starters positive conection to get power in the car to open the central locking one day. NOT a nice job!
come to think of it neither do i:confused::confused:
I will be definatly be stripping door down in week dident get a chance to do it earlier, 3 kids and all that!! Took me a year to relies I dident have a door key and it was the batt that went flat so I used a wire coat hanger took me 15secs to get in! Had to do the same last week at work when the locks failed! Im in the wrong job!!!
