after all the effort i went thru to find a manual.....
im sick of the heavyest clutch in the world! couple that with the engine hesitation when you set off its begining to piss me off id rather have gone for a TT auto instead of an NA manual!! same price most of them so my advice to ppl is sod a manual box there knackering!! (unless its just mine)
i always thaut jap cars were reliable? are Z's the exception to the rule? mates na supra never brakes down and he abuses the crap out of it!!!! grrrrr wish i still had my redtop calibra!!
  • Replies 57
  • Views 1.9k
sorry for the rant what i meant to say was is there any way of adjusting the clutch heaviness?
Have you any idea what type of clutch is in the car or where it was fitted ? any old receipts taht will tell you ?
smithy
Ive got 95 na manual the clutch is realy soft and responsive so may be replace the clutch fluid and thats all i can recomend
stock cluch is very light, I bet somebody has stuck in some silly ebay puck clutch.
oh is it fluid? i just assumed it was cable, fill it up thru the brake fluid res? it needs new pads anyway ill do the pads then the brake fluid - ill probably find it gets nice and soft after that.....mines a 92 model tho? aw i dunno!!
The clutch master cylinder is against the bulkhead on drivers side , smaller than the Brake master cylinder.
thats a point actually, when its been icy the clutch makes a weird noise when engaging and.... actually come to think about it it stinks all the time of slipping clutch.... it doesn't slip though - ill get the clutch replaced too!
sorry i was assuming the slave cylinder ran of the brakes like with 90% of GM cars with hydrolic clutches - used to find if all 4 pads were down to the metal the resivoir would drop quite considerably wich in turn would cause the clutch to slip everso slightly or smell bad when driving
Put the car in 4th gear with the hand brake on and see if the engine stalls when you try to move of with the hand brake on
good job iv got a delorian with a flux capacitor ill go back and buy yours mate!!
Have you any idea what type of clutch is in the car or where it was fitted ? any old receipts that will tell you ?
smithy
Geez, after all that then, did think about the above?
smithy
no i got a pat on the back when i baught it! - i barely got a v5 with it!!
Clutch seems fine, the so over to the others to help, unless you get in your delorian and set the flux thing to get your money back,
lol! i cant grumble at 1400 quid - its only done 60k well 63 now iv seen how much some of you'v spent on yours all it wanted was a cam belt when i baut it - think the problems its got now are my fault lol!
because i could'v had a twin turbo auto for the same price im 6'5 and go to the gym twice a week and i still struggle to press the damn clutch!
your not pressing the brake are ya??:rofl::D
Im 6ft1 and i can still ride my 3yr old neices push bike and i am a brike layer semi retired
