Allingawi-gtr
    Kuwait
Everything posted by Allingawi-gtr
  1. He he eh it's ok thanks any ways it's seems nobody change his came gears to adjustable ones thanks man im going to ask another tuner Sent from my G8142 using Tapatalk
  2. Its not about how to do it its after its done the idle will be the same? Sent from my G8142 using Tapatalk
  3. He says only intake came gears 2 degree advice [emoji28] bigger turbos and built engine Sent from my G8142 using Tapatalk
  4. Jwt 272 r5 camshafts jun came gears adjusting 2 degree will change the engine timing iwant to know the idle is stay the same Sent from my G8142 using Tapatalk
  5. Im going to adjust my came gears 2 degree is that affecty my idle stock cars idont need your comments thanks Sent from my G8142 using Tapatalk
  6. [emoji19] helpe or stop talking Sent from my G8142 using Tapatalk
  7. Im doing timing belt sarveic soon so my tuner ask me to adjust my jun came gears 2+ intake only is that coz a rough idle Sent from my G8142 using Tapatalk
  8. Ok thanks Sent from my G8142 using Tapatalk
  9. Are you sure cus my car is a tt [emoji28] Sent from my G8142 using Tapatalk
  10. Hi iwant to delete my spoiler This part will fit my car is it direct fit Sent from my G8142 using Tapatalk
  11. Good luck i delete it for good cuse some times its works some times not Sent from my G8142 using Tapatalk
  12. Delete it with fairlady z led or 300zx look much better Sent from my G8142 using Tapatalk
  13. Thanks all its done transmission and the deffrencel all perfect [emoji108] and the trans is smooth [emoji7][emoji7][emoji7][emoji7] Sent from my G8142 using Tapatalk
  14. Thanks man ill check again tomorrow Sent from my G8142 using Tapatalk
  15. Than im good i open that one but to much oil came from it never open the one on the bottom i remove the exhaust and open it im wandering whay is to much oil came from it i jack the car and fill this hole tell the oil came out Sent from my G8142 using Tapatalk
  16. This is the drain hole right? Sent from my G8142 using Tapatalk
  17. [emoji23] [emoji23] school boy iwil look for it and i hope its will open Ijack the car to a high level and fill it this way some oil will go in side the deffrencel its not empty and i close it tomorrow ill tray again If anyone have a picture of this fill hole please send it I even check on the sarveic manual didn't find it Sent from my G8142 using Tapatalk
  18. Tt [emoji28] where exactly the fill hole cuse by mistake the drain plug fill down and i lose to much oil [emoji28] what to do Sent from my G8142 using Tapatalk
  19. Hi where is this fill hole [emoji28][emoji28] i think im dead no oil on the deffrencel just drain it how to fill it i can't fill it on the drain hole the oil came out Sent from my G8142 using Tapatalk
  20. Ijust buy the redline 3 liters ill change it soon Sent from my G8142 using Tapatalk
  21. Thanks [emoji106] Sent from my G8142 using Tapatalk
  22. Any chance of whining or damage im going to use redline oil Sent from my G8142 using Tapatalk
  23. Hi i know how to do it I got the tools and the pump but is it ok to do it do i have to drain the oil put new or refill it Never change it from 2009 [emoji26] forgot about it Sent from my G8142 using Tapatalk
  24. I just Google about it some guys complaining about whining noise after changing the oil [emoji26][emoji26] Sent from my G8142 using Tapatalk
  25. [emoji108]thanks ill do it [emoji16] Sent from my G8142 using Tapatalk
