sheazx
    Ireland
Everything posted by sheazx
  1. Guys i am trying to vrt a 1990 300zx twin turbo,where would i obtain co2 and nox emissions document,Any info would be great,Thanks all
  2. Hi guys i am having a problem with my driver electric window switch,My drivers window wont go down,but when i press for the window to do up,i can her the window switch click,also my passanger window goes up and down from the driver panel,and the window lock button works,Is there any to open the switch as i cant seam to get it open,did anyone else ever have this problemAny info would be great guys,Thanks
  3. Hello guys,i am having a problem with cylinder 3,it doesnt seem to be firing,When i start the car and plug out the coil lead,The revs doesnt drop like the other 5,Also i used a fuel injector noid light and i am getting a pulse,would the injector have gone bad?Any info would be great guys,Thanks
  4. Thanks mate just ordered one hopefully will solve my problem
  5. hi mate no hazard switch is perfectly fine,with the old flasher unit in the flashers stay on but doesnt blink
  6. Hello guys,long time,Guys i have a problem on my z the indicators and hazards are staying on(both on dash and outside and all bulbs are working) but are not flashing,So would i be right in thinking it is the flasher unit under the steering colum,I have tried a durite 0-606-00,flasher unit but just keeps blowing the fuse,Would anyone what suitable flasher unit would work?and info would be great,Thanks guys
  7. got it working,was a corroded resister in the relay,broke up a old power blocked and soldered it in
  8. Mate is there any way to test it?
  9. That would be great mate,Can you also post a pic of the pipes,Thanks lad
  10. Thing is mate i live in Ireland
  11. Guys, my aerial was working a few months ago but now seems to stopped working,i have checked the on wire goin to the aerial and there seems to be no power,guys is there a fuse for the aerial or does anyone know what might be wrong,Thanks
  12. Japspeed exhaust up to the cats i think
  13. No i havent done a diagnostics as my cable isnt working for some reason,i found alot of leaks around 10 leaks but just cant find the last one,Seems to me that is is leaking from the plenum ,have a new gasket but the thoughts
  14. Guys i have 2.5 inch japspeed exhaust,but i was wondering where is the cheapest/best place to get decat pipes,Thanks all
  15. That would be great,mate thanks,will i post here my email,or what way?cheers
  16. Guys i have a question a few years ago,i got a few jobs done on my z,the mechanic said that the cats were bad on the car,78000 km on the car,At around 1,500 to 1,800 rpm while revving on and of the throttle i get a banging from the exhaust,it seems it coming more from the middle,would anyone know what this might be,And also it doesnt seem to idle properly,the car drops down to 600rpm and then jumps back to 900 then back down again,keeps doing this.I have uploaded a few vids sorry for the bad sound quality.Any light on the subject would be great,Thanks
  17. Guys quick question,does anyone know if phutumsch,still sells the conversion kit for 300zx rear lights,if not does anyone know where i would get the parts?Thanks all
  18. Guys quick question,how do i adjust the clutch?Also how do i know what slack(bite)there should be,Thanks all
  19. Hi guys,when i rev my car around 1500 and 2000k rpm,i get a back fire from exhaust,guys is this unburned fuel(new spark plugs),and would a series 2 ptu sort this out?thanks
  20. castrol 10W-30 i think mate
  21. Hi guys,i am getting a lifter tick,the car has been sitting for over a year hand it had a lighter tick the last time i started it,but has gotten louder now,Is there any way to cure it,Thanks
  22. Hello guys,Quick question has anyone bought a good car cover of amazon,If so which one,and what size should they be? Thanks all
  23. Guys quick question,How do these work or do they work,And what software is needed?14 Pin OBD1 To 16 Pin OBD2 Convertor https://www.ebay.ie/itm/Fit-Nissan-14-Pin-OBD1-To-16-Pin-OBD2-Convertor-Adaptor-Adapter-Cable-Connectors/163671148503?hash=item261b8f87d7:g:myAAAOSwnCxavG~D
