ted
Everything posted by ted
  1. Getting the urge to get one again in a couple of months keep looking at them as do miss driveing the zed
  2. Hope this is ok did anyone one here buy a set of apexi exhaust of me 1.5 years ago as I want them to go to the owner and i cant for the life of me rember there name as iv sold the zed
  3. Haven't got a clue who did it never used the car since buying it but it was pants under the fuse box and the cheap nasty halo have gone (So I can piggy back the side lights in the fog to the indicator lens
  4. Cheers mate
  5. I now have full lights woop one question can I have side lights in the fog light and also put them in the indicator lights would I need a relay to do it
  6. Sorry phutumch had to go to work and Iv lost my new phone not haveing a good wk haha nice one I'll check that today
  7. Rear lights are fine come on as that should fog come on when I press the fog button front and back there no after market wire from what I can see but on the 2 blue relay there 2 red white wires go into one on both relays that's crimp togeather
  8. When I turn to the switch to 1 nothing but a dim left fog drivers side only when I turn the switch to position 2 side lights work where the halos is but no head lights
  9. Just to be sure the dim relay thay are just earth wires there and the 2 blue relays are for side head and full beam
  10. Definitely a love hate relationship this car so I need to remove the loom from the light holder back to the relays and clean where that go
  11. Ok gone and checked the live fuse top 3rd from the left as Jeff mentioned and it is live checked the wires on both blue relays and all live so turned side lights on nothing apart from drivers side fog but dim put head lights on nothing but side lights come on put high beam on side lights go out but high beam on rear light work fine
  12. Just had thought would the hazard switch be a problem as mine is damaged
  13. Should have put testted the plug to the rear side light
  14. Hi Jeff yes back light are ok and if got chimes tested the side light plug when if turned the side light on and no power there put head light on powers there
  15. Hi Jeff yes pulled them all out and are ok got power to the fuse box under the bonnet when I turn the knob to 1 for side lights I get chime and click from relay but no lights check see if there was power on the light plug nothing put main beam on the side light come on but no main beam
  16. Still have a problem with the lights checked fuses relays the 2 blue and the black one all 3 clicking put a spare light switch on still no side lights only when main beam on if got side lights no main beam put high beam on side lights go off cleaned plugs on drivers foot well and checked fuses there
  17. Checked all fuses and the ones under the bonnet all good also can hear the blue relay clicking
  18. When I put my side lights on nothing, but one dim fog light when I put main beam on side lights work, but no main beam,when I go high beam side lights go off any ideas
  19. Ok replaced the fuse thanks Jeff put the wires on the sensor no reverse light put the wires together from engine bay lights on so took the sensor out of the gearbox put the wires to it prest the end lights came on is there a adjuster on the gearbox iv mist
  20. Thanks guys I'll look at them in the morning
  21. Hi Joe manual looks like iv got nothing even the plug under the bonet
  22. For some reason got no revers lights checked the sensor on the gearbox that's fine went to the bonnet looped pin 4 and 7 in the plug that should give me reverse lights but nothing where should I look now
  23. Looking for car battery for a n/a 70ah 63cca is this too big recommendations
  24. Auto box out and bering the manual bering in egr next and headers and water bypass then put the chrome on long time coming
  25. All sorted thanks tom
