dipone
Everything posted by dipone
  1. avatar is overrated it looks great but way too long and its just pocahontas with some smurfs, if i didn't watch it 3D i would have been well gutted about the film.
  2. yawn-a-rama for me why keep messing with the rules, oh and come on ferrari
  3. its not trying to get exact to a band but IMO mine sounds cr@p
  4. ok i have had a enough and i think its down to my amp is crap my guitar just doesn't sound electric enough. so can you recommend a good amd that will give good sound and also give a heavy metal sound too
  5. thanks guys. i use ultimate guitar for tabs, my amp comes with drive button and 4 pre sets clean, crunch, metal and insane but it becomes a noise. im not really able to get a setting i like and as for the sound mine just sounds so tinny no really umph. i was learning the solo to paranoid by black sabbrth and i can do it but it doesn't sound the same, like when im bending on the 15 fret, low E my guitar just sounds like a really high pitched noise
  6. i have been playing since christmas and enjoying it but i'm getting annoyed with the sound of my guitar or amp my. guitar is a strat copy thing with a rear humbucker and my amp is a line 6 spider IV. i have been having lessons to learn about music and also working off tabs at home and utube lessons, i have been learning black sabbeth, metalica and nirvana but i can do it but it doesn't sound anything like it (not cause im playing it wrong). i have messed with all my settings on my amp and nothing this is how i want my guitar to sound. after 3:30 http://www.youtube.com/watch?v=HgjKc5yrias any help would be great
  7. thats bugatti veyron drivers for you, they are all :xxx::lol:
  8. is it any good. i have taken most of my arms off my GTR to be powder coated and fitted with uprated bushes and adjustable arms so just wondered whats peoples opinion on them
  9. you must have seen my posts:2guns:
  10. my dog has to have Insurance LOL
  11. panasonic v10 or g10 for me i have both plasma and LCD and i do prefer the plasma much better colours and the reaction time on lcd's really bugs me, as for smsung i have heard some bad things about some of there tv's and i agree with above would not touch a phillips at all
  12. it wont stop the circuit it no differance then the TRV turning its self off. if the valves do leak buy 2 15mm comperssion stop ends and screw the male part of the into each rad valve
  13. shut the rad valves off both sides then undo the nut going into the rad to let out the water have a tub underneath or your thermostatic valve looks like it has a drain so drain the water from there. this will drain the rad but not your system then when you need to fill it again put it back together and open the vales and bleed but make sure you find out if you have a sealed system or open vented system
  14. thanks matey has anyone got W7 64bit is it any good?
  15. i have 8gb of ram as at the time i built my pc i bought 64bit vista but it was so crap i went back xp 32bit and it only sees 3 gb of my ram, will W7 be the same or not?
  16. happy birthday:duffer::duffer:
  17. happy birthday dude :happybday::happybday:
  18. i did guess but didnt want to believe it was
  19. ok someone needs to tell me who this is (PM), it seems like a well know member or is it Ztech again:scared:
  20. gutted for you mate too many people out to rip each other off, screw him over for everything you can get (if you can). hope no other members have used him
  21. the thing that gets me is he says he has installed a 6.5kw in his 3 bedroom house with 11 rads and at 0oC outside he gets his house to 21oC, and at 43oC air temp out side he gets 10kw and a water inlet of 20oC
  22. did not like 19 on my zed 18's all the way for me
  23. so you believe the guys tech and his "tried and tested" description?
  24. mate you need a sparkie to look at it, it depends if you loop is done in the ceiling but some aren't and do in the switch so this needs to be found. you should have 3 wires in each switch if done the way its wired in today. you need to look behind the light to identify what cables do what as this should show you the live, neutral and loop, this should help show what cables are what in your switches. turn the power off and do a continuity check across the wires to show you where in the light the switch wires go
  25. whats your thoughts on this, i dont mean heat pumps in genral just this make, decription and tech info http://cgi.ebay.co.uk/AIR-SOURCE-HEAT-PUMP-OIL-GAS-BOILER-REPLACEMENT-8-3KW_W0QQitemZ270358499009QQcmdZViewItemQQptZUK_Home_Garden_Hearing_Cooling_Air?hash=item3ef29f4ec1
