ZXmark
Everything posted by ZXmark
  1. Lovely !!!!!!!!!!!!!
  2. And the stupid bloody thing won't come out without dropping the exhaust!!!!!
  3. Cheers for the info, i'll take a look. nice one
  4. Hi Guys, Anyone know, Is there a difference between an auto and manual speed sensor? And where can i get one for a manual? cheers
  5. Sweeeeeet! found a pipe on the intercooler under the engine off, Still a bit rough now i pushed it to work like a **** but hopefully that'll clear up. Just reset the ecu so maybe that'll help. Thanks for the info guys
  6. It's a TT, Haven't seen any pipes off yet, gonna try getting under the car now. Now she's cooled down, she start rev's ok but not to full level, pop's a little when lifting off the throttle and a small amount of black smoke form the exhaust. cheers guys
  7. Driving to work this morning and the car was fine till the carriageway where it accellerated fine through to third popped in to fourth and not much power. Managed to limp to work with a rough and louder car the idling was irregular, initially she'd rev with the clutch in but that worsened. After about 10 mins some but not loads of black smoke from the exhaust. By the time i got to work it was hardly revving or accelerating. Any idea's guy? :no:
  8. Just passing a house the other day and noticed a black z on the drive here. Any who's registered?
  9. I was thinking double sided sticky tape!
  10. Hey all, anyone got fitting instructions for a central front mounted intercooler? Cheers Guys
  11. Hi all, How easy is an electronic boost control to fit and where does it fit to? Cheers
  12. Has Anyone else had a problem with the speedo intimitently working after swoping the dial cluster in an import car to a UK MPH cluster? Once it's working on a journey it's fine, but the time taken to start is totally random. The rev counter works all the time. It's driving me nuts, but i can't tell at what speed!!!! :taz:
  13. hi, I've got a black wire connected to the drivers side of the gear box with a 14mm bolt. The other end is not connected!! I'm guessing it's an Neutral cable but will it make a difference being disconnected as it is? Cheers
  14. it's not linked to the brake system in any way is it! i've flushed the brake system the noticed the clutch res was empty so don't know if it was like that or i've done it!!!!
  15. Hi guys, Just wondering what the small reservoir is just to the right of the brake fluid res? Is it brake fluid too? cheers
  16. Hey all, anyone know the ordering in which to bleeding brakes including the abs pump? Also, is there 2 pumps or just the one in the boot? Cheers
  17. if i'm off, i'm there. :-)
  18. nice, I got a track day. can't wait :-D
  19. Always loved em and thats a beauty. I should have bought one the year they stopped building. Prices have just rocketed since. DOH!!!
  20. ZXmark replied to ultimaterayray's topic in Events - UK
    bloody work!!!! Doh!
  21. Cool, cheers for the info.
  22. Hi all, I'm giving my brakes a full overhaul shortly, Braided hoses bigger disc's etc, you get the pic. When it comes to the brake fluid whats best? Dot 4 Super dot 4 Dot 5.1 silicon based but fine for ABS or any other options and opinions? Cheers Guys :rockon:
  23. Is there such a pad that will fit the standard calipers but are wider to cover the disc surface area?
