pete-flint
Everything posted by pete-flint
  1. The other half and my self will come over the border, yet again, just for the merry banter and joviality. 11.30 for 12.00, see you there Pete.
  2. Smoked for years, given up giving up. Woe betide the nerdy git that points out the fact that smoking is anti-feckin social. It is anti-social to stub ciggies out on faces, so don't try it.
  3. Take that scoops.... It was a good location, a lot busier for hill walkers than Z Peeps Nice pics of most of the cars Graham ! !
  4. Some other probs. to look-out for:- Prop centre bearing Gear selection, syncro baulking on 2nd and 4th As previous, Targa roof seals. If panels not replaced properly the seals fold over and you get a wet a*se, or some twonk has put silicon sealant around it. Clutch, can be a big problem for single handed D.I.Y. Water pipes/hoses, there are some awkward buggers to get at, under the inlet manifold, either side, and one little bute above the N/S turbo at the rear of the block. Other than that, they are rapid motors and possibly a bit rarer than a Skyline in some areas.
  5. Thanks to Andy and Carl, car running as sweet as a nut. Cheers Guys.
  6. Is there anyone near Flint who would like to volunteer their services with the diagnostic pad on the car belonging to my other-half. It miss-fires and nearly stalls when accelerating at about 2000 r.p.m. It's a daily user so it doesn't stand for too long, and the fuel filter is also new, plugs O.K. Air filter O.K. also.
  7. Have a 3 foot 1/2 inch extension handy to remove the top bellhousing bolts. http://www.ttzd.com/ Click on TECH in left margin and scroll down main page to clutch and flywheel replacement.
  8. After much cursing,swearing and bashing frozen fingers, the Fairlady lives and breathes. It appears to have been "water" in the fuel system, must have collected in the swirl tank and then fed to fuel rail. For future reference, pump at least half a gallon through the filter before trying anything else, if you ever have a similar problem. Many thanks for the suggestions. Happy New Year to one and all, Pete.
  9. The bolts you broke hold the two halves of the caliper together. They will need replacing or they will split apart when brake hydraulic pressure is applied. Don't split them. It may be better to either take it to a decent engineering shop or get another caliper from someone who is breaking a car up.
  10. Thanks guys. I've had the plugs out, they're O.K. gap 0.035",cranked engine and fuel flowing into container while cranking O.K. Will remove CAS and listen for injectors ticking once I get circulation back in my hands, friggin' freezin, I think my brain has frozen. Once again thanks guys, have a Merry Christmas, hopefully Santa will tow the car away and fix it !!!
  11. I did do a search before I asked the question, but nothing came up. I would have thought someone MUST have had a similar problem at some time, never mind. Didn't want to start WW3. Will check CAS and number of plugs firing also fuel flow. Regarding fuel, does the regulator (the little diaphram between 5 & 6 cylinders) control the injector fuel rail pressure and is it possible to hear the injectors "ticking" when they operate ? Commence "Round 3", sorry guys, couldn't resist.
  12. Thanks for the tips,will see how I get on. Cheers.
  13. No apparent smell of fuel from exhaust when cranked.
  14. Car started fine, reversed out of drive and died. Checked, (1) Spark = O.K. (2) Uncoupled fuel filter = Gushed out when ignition turned on. (3) Checked ECU = reading 55, no faults. Any other suggestions, HELP.
  15. Received, good quality and some excellent bodies to peruse.The better half even looks at the colours too !!
  16. pete-flint replied to a post in a topic in Events - UK
    Sorry folks, due to shortage of available room at the inn we will have to arrange something when the weather picks up.Sorry. Perhaps someone has another idea ?
  17. 1. Steve-300ZX 2. MAC 1 3. AndyP 4. Jason Farrow 5. Mike Groves 6. Shunter 7. Mowgs 8. Moggy 9. Lampshader 10. Funkysi 11. Deve8UK 12. Paulzx 13. Apache 14. Captain Slow 15. icu812 16. cybernet 17. Bantambunny 18. Spinksy 19. alex300 20. Legrath 21. piesoup 22. scartlead117 23. Craig David 24. Suzy 25. diddy_p 26. Jonce 27. Shep 28. Peach 29. Z Evo Guy50 30. Z Evo Guy 31. Paulbrem 32. StellaZ 33. DCarey 34. viniboy 35. na_kins 36. Filthy Fill (One) 37. TiZer 38. Darkside TT 39. tzee 40. Ossian 41. Lee M 42. mantav8 43. Bobby Ball 44. Machine 45. clarkmagpie 46. ChrisD 47. Joely P 48. Mick1 49. The Dark Warrior 50.Corvetteman 51. Markzx 52. Coolnick 53. FairladyZgirl 54. Big Marty 55. carls got a zed 56. Mark W 57. ianl 58. Alfo 59. CADpaul 60. tulip 61. scubie 62. hunnipie 63. Bird 64. bad_monkey 65. nad300 66. BigDaveZX 67. Moby 68. Sinclair 69. dafridgea - wahoo!!! my first 69 70. Yewcheck 71. rucksack_15 72. dave300 (2 please). 73. dave300 74. Emero (2 please) 75. Emero 76. pete-flint
  18. pete-flint replied to a post in a topic in Events - UK
    Sorry guys, just logged on and found p.m. a bit late I know but, if you don't mind mixing it with some Skyline owners there is a Christmas do being organised at the Afon Conwy just off the Llandudno / Llanrwst junction A55 9th December. Lee, the guy that runs the place is a Skyline owner so the mental thing runs through us all. Let us know how it sounds ? May have to check if there is enough room for everyone, but will keep you posted.
  19. Don't forget tyre pressures, I've found 28 p.s.i. all round on 235 - 255s is a good ride and doesn't appear to affect tyre wear.
  20. Hammond is in the picture, but the grass is tooooooo tall for you to see him.
  21. As advertised in Jap Performance. The "picture" does look good for the money though.
  22. It may have taken a little while, but received the goodies on Friday. Will now spend hours boring my mates flashing the BLING.
  23. Hole centers for four bolt mounting are 55mm X 95mm, orifice approx 73mm diam. Any use ?
