Spartan-117
Everything posted by Spartan-117
  1. still no joy. have checked all the connectors and they seem ok. did find the front fog light fuse had blown and replaced it. cant work out why the main beem comes on when on dip forgot to say its a s1 jap spec
  2. both fuses in the engine bay are ok and i'v only just repiped the targa, will check the plugs again, maybe something has come loose killing the headlight control
  3. I get no front or rear lights on (even side lights). if i more the headlight switch to full the main beem comes on even tho the control stalk is in the nutural position. The fogs have also stopped working. i did have the main fuse box out in the driver footwell. Is there any headlight connections in that area. If so what plug??? cheers
  4. cheers for the replies. I take it the passenger side drain plug can only be found by taking the wing off then? so the horn cable comes straight from the engine bay fuse box to the steering column?
  5. Just repairing some electrical issues with the old Z and needed some better information: does anyone know which connector the horn is located on in this pic? also on other pictures i have seen, there is a black connector next to the big brown connector. Am i missing some wiring? Does the water pipe for the targer come in around this area, i cant find the pipe cheers
  6. dont no if this will help http://www.300zx.co.uk/forums/showthread.php?t=155686
  7. i always check the dipstick by 1. letting the engine cool down for several hours 2. take dipstick out and wipe it 3. place dipstick back in making sure not to twist it about 4. remove dip and check oil level, all the way round the dip. the lowest mark should be taken as the proper level. hope this makes sense
  8. thanks, might just unplug them from the box and feed them out, instead of unscrewing them from the cat.
  9. are they required for the car to opperate correctly? need to remove the exhaust but i'm a bit worried about breaking the bolts that holds the sensors in as they are rusty. do you know what page these connectors are on, inthe service manual?
  10. 91 jap import TT LWB looking at my exhaust there are two braded lines going into the side of the cats. these lines then dissapear into the cabin though a rubber hole. i assume they are sensors of some kind? I have tried to find a reference for them but with no luck, so hence the post. cheers
  11. Spot on. Car is now running again thanks mate
  12. Thanks man, only had the car a month and its a propper mission getting it running how i want it. Will try this tonight
  13. just wanted to see if anyones got any idea's for my Z car was running fine the day before. Got in it dismorning and it started but i then stalled it :death: and now the Z wont fire up. The engine turns over but does not spark to life. I have charged the battery just in case. Was thinking it could be the fuel pump or PTU (bit strange as it was fine the day before) Anyone else got any ideas for me to check?
  14. never mind found a good guide for the tps. will also check the other stuff out when i get the time. (dame the 300's complex!) cheers
  15. where is the tps and adjustment pot
  16. how is the tps checked, not sure what pins to use. does anyone have a picture?
  17. should have said when satationary after a hours dirve the revs are aound 1.5 - 2k
  18. on startup the engine idles around the normal 850rpm. after a long hour's drive to work, the revs sit around 1500 to 2000 and doesnt seem to drop off. not sure if this is right for a zed or not?
  19. hi all, in the middle of the timing belt change. (done changes before on the old 200sx) was reading the manual for the timing belt change and came to the section about Removing the SparkPlugs. do i need to do this? (cant see a reason to remove them) Why do you have to move the crank 10Degs when installing the auto tension tension, seen on page EM19. is it to bed in tensioner? was just going to line it all up and rotate the crank just to make sure nothing hits inside last question, honest.. what page is the timing setup on (strobe light etc) cant find it cheers :clown:
  20. thanks mate, was worring id rip the steering out. will try turning the triangles, but a picture would be great. cheers
  21. hi new to the zeds and mine has alot of play in the steering wheel. when you pull it it has some forward travel and some play pulling it left and right. I have checked where it bolts on and all i can see is the two triangle blocks that attach the steering wheel to the console. is it spose to be like this? cant find a good picture or diagram of how its ment to be (even on the online manual) :huh:
