Schumi_not
Everything posted by Schumi_not
  1. Auto wiv body kit. Spotted driving past you in another RedZed... :dance: Eye catching for sure!
  2. lol Aye was it! Hold on... Let me ammend that! :D
  3. Your the Red zed auto with body kit right? :tongue: You've seen another Red Zed in Reading if you are! ;o)
  4. Rust on the rear wheel arches is a common issue, mine need doing too...
  5. Eh? Mine is 17 years old a flew through the emmisions test, new exhaust and new cat. How old is the exhaust system? What reading did you get on your cert? Its gotta be a sensor surely... I found the best way to get work done is diagonose it with some help on here and do the work yourself.
  6. Whoa... Wtf!? Easy now! Well.. Quote me a ****in duck... I guess the info i read is wrong. :headvswal I'll be a sceptical git when it comes reading everything that is written about a Zed. :mad: :wack:
  7. Hi Glen. 1600 kgs!? Do you have lead wheels or something m8? When reading up on the Zed, i was under the immpression they were 1000kgs... Hence hitting the 'majic' 300bhp per ton. No doubt someone will post accurate figures! lol Anyway...What ever! Not bothered! :D I'm off for a :duffer: or two!
  8. Yes to the above! :D Leather, cruise control, air con 4 wheel steering,abs all round... And nigh on 300bhp for a car that weighs a 1000kgs... As standard! ;o)
  9. ^^Yep... Manual TT... Or if you prefer some additional petrol in you tank, a manual N/A.:D Check out the buyer's guide on the previous page posted by 300zx girl. Start at 3.5 - 4k for a decent runner. Any further advice needed, just ask on here. :)
  10. Ok chaps. My zed had some re-spray work done by the previous owner and i dont think much of the job done. Yesterday, my car 'aquired' additional splash's of white paint all over body work, and trimming, from a jet wash brush @ Morrison's Petrol station in Reading.Liability aint mine, so need a recommendation on where to get a full body re-spray done proper. I live in Reading, but not to fussed on where it gets done as long as it is done professionally and looks sweet as when i get it back. I am also looking to get the rear aches cut out and replaced at the same time and the tailgate replaced as these have gone rusty in places and need changing cutting out.
  11. The gear boxes are normally pretty solid, is your Zed an Auto? I was thinking syncro or clutch setting.
  12. Does'nt the lock barrel have the key code on it?
  13. Dunno if this is related but... Had a similar problem 4 months ago,i changed to a series2 ptu, no diff', so went through every dam eletrical connection and contact cleaned everything. Coil packs the lot... Runs sweet as now.
  14. lol:D Hmmm... Good point m'man. My rear wheel arches need cutting out and replaceing... Oh...And the spoiler too... Probably be a replacement tailgate in the near future. At least its only body work...Easy and cheep repair, just a little time consuming.. Today i'll be removing the front end, re-tapping fixing points for the front nose after an accident while stationary with a cyclist! :headvswal
  15. 2K for a TT? Abs light always on and boost gauge not working? If i were you, i would walk away... Save you money up and buy a sorted one for around 3.5k - 4k. '91 plate onwards, manual uk spec ideally, stay away from Auto's too, from what i'v read on hear Auto's are a tad less reliable and prone to 'issues'. Sounds like your going to find brakes disks, pads, gauges and turbo seals are in need of replacement and you WILL be shocked at the price for replacment parts. Before you can replace a turbo seal you will have to pull the engine out... Turbo seal - 20 pence Engine out - 700 quid labour alone... Just so you have an idea of what you could be letting yourself in for, a new exhaust system (with CAT) will set u back nearly a grand. Half the price off the car you could be buying. Save you penny's and look else where m8, that my advice.
  16. http://www.twinturbo.net/ttnetfaq/FAQpages/differences.html '90: NA begins production in Spring '89 -- TT begins in the Fall. Extended model year sales: 39,290 '91: Manual climate controls discontinued (except in convertible). New electronic climate controls allowing control over air flow direction, but no more ambient temp gauge. Nissan hamburger logo put on nose of car. Driver's airbag now optional. Air Conditioner evaporator valve changed from aluminum to steel to quiet it. NA rotors changed to TT units. Previous NA rotors were 2 mm thinner. CD Player option added for both TT and NA. Previously only available in NA. Bose stereo head unit changed. Logo on floor mats changed from "300ZX" to "Z". Hardtop coupe available at mid-year (NA only). Brake master cylinder changed to new unit in Feb. 1991. Keyhole on driver's door and interior light illuminated when driver's door handle is pulled. Sales: 17,652 '92: Driver's airbag made standard. Brake caliper material changed from aluminum to iron, to help warpage/shimmy problems. Dash/door complimentary material changed from fabric to suede. Separate mirror heater switch eliminated (combined with rear defroster switch) Mirror heaters made standard. Power adjustable driver's seat standard on T-top. Sales: 6,708 '93: Turbo oil line insulation changed for better heat dissipation. Convertible option added. Upgraded Bose stereo made standard. AIV/reed valves removed. Sales: 11,599 '94: Rear spoiler design changed to a higher/bigger pedestal one. Super HICAS system changed to an electrically actuated unit (previously oil pressure act). Seat belts redesigned. Moved from door mounts to true pillar mounts. Passenger airbag made standard. Keyless entry added. Titanium keys discontinued in Nov. 1994. Off-white 'Pearl' color is dropped. Future 'pearls' are more of a semi metallic white. Sales: 5,320 '95: Front fascia becomes body colored instead of gray strip. Special 25th Anniversary gold paint available. 'Reset' button removed from dash clock (may have happened in '94). Sales: 3,135 '96: Variable cam timing 'quietly' dropped due to smog regulations, reducing 5 speed engine output to 280 HP. Different cams installed to compensate for lost HP (total still at only 280 HP). OBD II electronics introduced. Driver's seat back rest no longer includes adjustable side bolsters.
  17. Zed's eh???:D Check your fluid levels m8, i get a hot oily smell, (from the turbo casings i imagine) almost every time i drive mine for an extended period.
  18. I'll pass... Dunno. Someone on here will have the info tho. Tried looking through all previous threads to see if something similar has been mentioned before?
  19. Well done on your purchase mate. :D Jeez on the insurance quotes... Try Quote line direct;
  20. lol... U never been there in your Zed then? :nana2:
