pete shrimp
Everything posted by pete shrimp
  1. Great stuff Rich :hyper: Glad to hear it went well, fingers crossed for ya :)
  2. Great stuff Mike thanks :bow:
  3. Do dogs have gears? :confused: ;)
  4. Nope, still could be anyone taking the picture :x::rofl: Sorry Chris :D EDIT - fun sized marsbar to Jimbo :cool:
  5. Can anyone see the clue giving away that Chris took those photos? :rofl:
  6. Who's is that and when's it being lowered? ;) :bow:
  7. http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=CP&Product_Code=22680-Z32ALL Courtesy Nissan site says they are the same :cool:
  8. Hmm dont know sorry, got that P/n from this picture http://www.300zx.lv/catalog/?gr=B&sec=165 which looks like an NA set up, if they are different.
  9. Hi Paul http://www.300zx.lv parts search has it as 22680-30P00 Mass Air Flow I hear the AA do a decent low rate loan, if you're buying a new one ;) Pete
  10. pete shrimp replied to a post in a topic in General Discussions - Non 300ZX
    Cats are too tough for their own good sometimes, as a last resort they will usually turn and face and oncoming car at the last moment when they'd be better off turning away.
  11. LMFAO :rofl: Hey I was impressed I got it in the garage :D
  12. Yeah Dave - I find even the simple jobs on a zed turn into complicated ones lol. Have you got the stock scissor jack to raise the car a touch first? See Aaron - its a faff!
  13. I read 6.5" when searching before fitting mine ages ago. Bought 6.5" but the screw holes dont line up, physically they fit in but I consequently found references to 6" ones. Wonder if there are different sizes amongst series models?? Mines a 1990 Jap
  14. pete shrimp replied to a post in a topic in General Discussions - Non 300ZX
    good luck to her matey :)
  15. 6" rounds in the front, 6x4s in the rear :)
  16. Well not really but check this out. This man is a fook up :xxx: http://news.bbc.co.uk/1/hi/wales/3978957.stm
  17. Aye mine doesnt want to move because of the ripples - good idea about the carpet :cool:
  18. Aaron I'm sure you're right but the car is pulled towards where the trolley jack is pointing, because the jack lifts in an arc. Why wouldnt this pull the front axle stands over? Just off to powder me nose :D
  19. Pitted? Wouldn't pitting just rub off?? - like surface rust?
  20. Must have missed this - blimey, look at the mods list! http://www.sxoc.co.uk/vbb/showthread.php?t=119248 This really is about the worse thing I have ever had to do but I have no other option now but to sell my car due to circumstances out of my control. It is a white '93 S13 Personnal Reg "K550HP" with full ND development to circa 630bhp. The car has had everything needed doing at no expense spared with over £75,000 spent on it to date, recipts to prove. I will also be letting the car go with 29, 18" tyres of various compounds, 8x Kahn RSR 18" wheels, 2 drag radials with custom Compomotive MO rims, Motec laptop and software for mapping, lots of other spares including airfilters etc. I have lots of photos and video's but serious buyers really need to take a few test drives. Open to offers around £24k. Tech Spec: Performance: - 0-60mph 3.56sec 0-100mph 7.419sec 60-100mph 4.07sec 0-150mph 15.8sec Engine Mods:- CA18DET 1809cc Turbo 9000Rpm Rev Limit Best Top Speed So Far 186Mph ND Forged Low Comp Pistons ND Chrome Piston Rings ND Metal head gasket ND Lightened & Balanced Bottom End ND Prototype Flywheel & Clutch ND Steel Billet Crankshaft Trust Steel Conrods ND Lightweight Solid Lifters Tomei 260 Solid Profile Camshafts (Currently HKS 264 cams) Tomei Wide Coil Valve Springs Tomei Adjustable Cam Pulleys ND Race Spec Cylinder Head (GT Combustion Chambers) ND 1000cc Fuel Injectors Full Dash 8 Fuel Lines ND Large Bore Alloy Fuel Rail ND Prototype large bore throttle Modified throttle pedal ND TPS ND Prototype inlet Manifold (3" Inlet) ND Prototype plenum SARD Adjustable Fuel Pressure Regulator Bosch Motorsport Gp B Fuel Pump Motec M4 Pro Ecu Motec Launch Control ND Full Engine Management System Loom Bosch Idle Control Valve Full Greddy Turbine Kit TD06-25G Modified Low lag 25G turbo 360* oversize thrust bearing Greddy external wastegate ND Prototype Rad Stant High Px rad cap Mocal oil cooler system Remote filter housing ND Prototype Front Mounted Intercooler NX N-Tercooler 3" Intercooler Pipework Samco Blue Hoses Cusco Catch Tank ND Breather System inc Sump Return 8.0 To 1 Compression Ratio AEM CDI ND Coil pack HKS 40i Plugs K1 Racing Leads Apexi Filter 4" RB Alloy Filter adaptor HKS Super Dragger Full Exhaust System 3" Turbo back exhaust 3 Bar Map Sensor Nismo oil filler cap Remote Mounted Battery Alloy BatteryCover ND rocker cover Polished cam cover Polished PAS tank Transmission:- OS Giken Long Ratio Gearkit OS Giken 600bhp+ Mainshaft S14 rear housing ND Twin Plate Clutch Assembly ND Quickshift Kit ND Prototype Flywheel Interior Mods:- Greddy 60mm EGT ND Boost Gauge Kit ND Oil Pressure Gauge Nd Oil Temp Gauge RB Alloy gauge mounting plate Weber Alpha Lambda Monitor Greddy B Spec Boost Controller 2.5 BAR Greddy Turbo Timer Sparco Bucket Seats Nismo gear knob Momo millenium steering wheel Momo boss Nismo Key Luke 3" Harnesses Stripped rear chassis Chassis Mods:- Leda 2.5" Race Coilover Suspension Kit Nismo Rear Sub-Frame Bushes (X 4) Lowered 80mm All Round Whiteline Front anti roll bar Solid Steering Bush Lightened to 1100kg Brake Mods:- ND 355mm Front Brake Kit Goodridge Braided Hoses Mintex Synthetic Brake Fluid Mintex F4R Front Pads DS2500 ABS Removed Wheel Mods:- 18" X 8" Khan RSR's x4 Dunlop D01J 235/40/18 Tyres for racing 18"x 7.5" Khan RSR's x4 Avon ZZ1 225/40/18 for road use 15" X 10"Compomotive MO's BF Drag Radials 26" X 10.5" Ice:- Clifford 600 Alarm All Ice removed Exteria:- Jun front bumber Jun side skirts Eiribuni rear wing Jun rear 3/4 panels Various decals Personalised plate Coming soon:- 32psi boost px Stats: BHP 532.6@hubs @28psi Torque 484lb/ft 0-60 3.56sec Qtr Mile 11.4@ 129mph +7 IGN ADV Top Speed 207mph @9000rpm __________________ 0-100mph 7.419sec http://www.norrisdesigns.com
  21. Did you say you'd bought a Countach? :cool::bow: Got any pics? Whats it like to drive/own? In no more than 1000 words ;)
  22. That Mrs of yours can never keep secrets! :slap: When does she want those nipple clamps back mate?
  23. PMSL Ryan, I might have some old bicycle tyres somewhere :D I'll build a small wall under it with bricks I think ;) Tell you what the spacesaver is useful for - I forgot to loosen off the front wheel nuts before raising the car :rolleyes::xxx: but wedging rubber against rubber held the fronts enough to stop them turning.
