hks evc 4
what are the readings in on evc 4? I do not wish to fiddle with things as they are running great and was fitting on the car 5 years ago in japan by the looks.hks evc 4 on the lcd reads 0.7 low and 0.8 hi settings are these in bar?(bar seems to be more likely) or kpa? cheers in advance also anyone have a pdf of set up
Edited by 8ace
in Japan, they use KG/cm2
its more or less the same as Bar (slghtly out cant remember which way)
i would class 0.8 as high tho! think you need to adjust the settings.
0.8 bar is only 11.76 psi if it is in bar so should be on the low side found a bit of info and it does look to be in bar just need to be sure. It's not flying off the stock gauge or anywhwere near, goes just sweet
Edited by 8ace
