Just wondering if the front lower ball joints can be changed or does the whole arm need to be changed?? Just that i found these on ebay. Just that i want to get the whole running gear new and tight :cool:
http://cgi.ebay.com/ebaymotors/2-Lower-Ball-Joint-Nissan-300ZX-1990-1996_W0QQcmdZViewItemQQ_trksidZp3286Q2em63Q2el1177QQhashZitem260304655551QQitemZ260304655551
yes you can just change the ball joint, any garage with a press should only charge around 20-30 quid to do it
Cheers buddy. Get those ordered later. I will fit them myself. i never pay anyone to do anything because im a tight arse :rofl::rofl:
fitting yourself is virtually impossible mate, you need like 2-3 tons of pressure minimum :smash:
Although it can be done with a good bench vice, some big sockets and an extension bar, but i wouldnt recommend that :rolleyes:
isnt it the same price to get a new wishbone?
the wishbobne has to come off to to this, and the new wishbone would come with the new joint.
or am i mixing this up with changing the bushes? :slap:
:rofl:its not the rears, its the fronts i think he means, and its not a wishbone, its a lower arm :D
and last time i priced a new lower arm and wishbone it was 175 plus vat ( diff car though, 200sx)
so i think this may work as cheaper
  • 2 months later...
Did you manage this yourself then ?
Not bothered to do it yet lisa. If you have a good vice a lump hammer and some heat im sure it would pop :)
Just put plenty of grease on. They should pull into place when you tighten them up on the hub housing
I need to do mine but i cannot be bothered :rolleyes:
