Anyone bought brakes from this bloke?
  • Replies 64
  • Views 1.9k
Sounds tempting, I take it they were used on these disks?
How much pad do they have from new, about 12mm?
yes used on the same discs, pads are normaly 10mm new.
Cool, chuck em in then :)
Just need to get a set of the bolts etc off the bloke on ebay now.
So all I need is the bits in the picture?
Will the bits from his 315mm kit do the job as your disks are slightly larger?
Or is that all taken care of by the caliper mounting brakets?
only parts you might need would be the bolts think ive got them somewhere but cant guarantee that.
Ok let me know what you can find, no rush.
What are the big thick washers in the pic for?
There spacers about 3cm. could be a bit dodgey mixing and matching :confused:
I take it I need them then?
Yes but they might not be the right measure ments for his brackets
How much are you saving?? Might not be anything if nothing lines up. only needs to be 2 or 3 mm out and you will have all sorts of problems.
as ive already said all you might need is bolts got everything else you need to fit kit including spacers.
As long as everything fits on your car then it should fit on mine :)
