how do most of you have these?
in with the rear brake lights?
Anyone got any pictures
Membership No 0780
INSURANCE GOOFA
I've converted one of the reverse lights :) Whack a red bulb in with some extra wires and jobs a good un :D
HTH :)
good idea, on the rear cetre panel could you not use 2 of the 4 lights?
Membership No 0780
INSURANCE GOOFA
Thats what i meant bud ;) Its not 4 lights BTW, its only 2, just looks like 4 :) If you look at the back you'll see there is only 2 bulbs.
HTH :)
found some neat little lights that can be used as fog light on ebay, i motorcycle parts under led brake lights,about 70mm long by 12mm thick they can be bolted under rear lip of bumper and dont stick out like a sore thumb. and yes they will pass mot as long as they are fitted to o/s of car.
hate the big towing fog lights :rant:
i too have a red bulb in my reverse light, with a manual switch onit.
my other reverse light doesnt work tho (common problem)
luckily you dont need reverse light for MOT :)
i had this prob too last year, wired into off side reverse light and change bulb to a red one, cost about 40 quid. was wired into brake light on spoiler and failed MOT like that.
So long as it is mounted on the O/S of the vehicle the only requirements are that the bulb be a minimum of 21W (or equivalent there of if using LED) and if using a separate switch inside the cabin it MUST light up when the fog light is in operation.
Dan
