import rear fog lights
how do most of you have these?
in with the rear brake lights?
Anyone got any pictures
Membership No 0780
INSURANCE GOOFA
I've converted one of the reverse lights :) Whack a red bulb in with some extra wires and jobs a good un :D
HTH :)
good idea, on the rear cetre panel could you not use 2 of the 4 lights?
Membership No 0780
INSURANCE GOOFA
Thats what i meant bud ;) Its not 4 lights BTW, its only 2, just looks like 4 :) If you look at the back you'll see there is only 2 bulbs.
HTH :)
found some neat little lights that can be used as fog light on ebay, i motorcycle parts under led brake lights,about 70mm long by 12mm thick they can be bolted under rear lip of bumper and dont stick out like a sore thumb. and yes they will pass mot as long as they are fitted to o/s of car.
hate the big towing fog lights :rant:
i too have a red bulb in my reverse light, with a manual switch onit.
my other reverse light doesnt work tho (common problem)
luckily you dont need reverse light for MOT :)
i had this prob too last year, wired into off side reverse light and change bulb to a red one, cost about 40 quid. was wired into brake light on spoiler and failed MOT like that.
So long as it is mounted on the O/S of the vehicle the only requirements are that the bulb be a minimum of 21W (or equivalent there of if using LED) and if using a separate switch inside the cabin it MUST light up when the fog light is in operation.
Dan
