Fuel Pressure
Isn't the fuel pressure supposed to be around 35psi at idle?
Mine is around 45 psi at idle. Tried unplugging the fuel dampner. The idle changed a bit but the fuel pressure was still 45psi??
made a mistake. Going to unplugg the fuel pressure and see if it makes any differenCe. What else can cause high fuel pressure Other than the fuel pressure regulator?
