seatbelts
hi all my passenger seat belt is pulled out at max and it wont return back becouse its fully out can this be fixed? or do i have to get new belts etc thanks in advance :bow:
Take the door card off and unplug the connector from the recoil barrel (This is presuming you have a series 1 of course). Nissan designed in an electronic seatbelt slackener. Works fine if the seatbelt webbing is brand new and the recoil mechanism nice and oiled, but the rest of the time it's a PITA and it gets worse as time goes by.
It will go back in if you mess around with it and the buckle lock. Put the key in the ignition, turn the ignition on and lock the seatbelt as if you were going to drive, this primes the electronics for the seatbelts. Then give the seatbelt very gentle tugs. Eventually, the recoil mech will release. But once it is, when you have a chance, take the door panel off and disconnect it and clean the belt webbing. It should prevent it from happening again.
ok thanks funks ill check it out at the weekend
