rear fog switch
Is there a legal colour for the rear fog light switch illumination or could I have blue ? :confused:
Cheers Maz.
Cheers Maz.
If you mean the inside switch, you can have it any colour you want i think, i doubt it even has to illuminate TBH, infact i know my dads does'nt.
HTH :)
yep the fog light switch must light up...and i wish for some drivers they would fire out an eye piercing dart to remind them to switch off:mad:
I agree about the eye-piercing dart, but can it be any colour ?:D
the one fitted to my zed is a red led and it passes every year....then i undo 1 10mm bolt and take the foglight off:D
http://www.motester.co.uk/cog.html - doesnt say much about switches
Lights
The headlamps are checked for alignment with a Beam Setter. After first aligning the equipment with the vehicle, the left and right headlamp beams are checked to ensure they are correctly set so as not to dazzle other road users.
Test Description
All required lights are checked for:
* operation
* condition
* security
Side lights and headlamps
* are the correct type and colour
* dip and aim.
Stop lights, indicators and hazard lights
* do not interfere with each other in operation
* driver's tell-tale works with respect to indicators, or there is an audible warning system.
Rear Fog lamps**
*must be fitted to the centre or offside of the vehicle
*tell-tale must work
*must not be affected by other lamps and not be obscured
*must be red.
Number plate lamps
*All lamps fitted must be working.
*Rear reflectors
There must be two red reflectors fitted reasonably symmetrically, securely attached and not obscured.
* Must be fitted to all vehicles first used on or after 1st April 1986, but if fitted, must be tested.
** Must be fitted to all vehicles first used on or after 1st April 1980.
I've got the 2nd one down - but mine is red.... although they do sell in other colours...
http://www.nfauto.co.uk/all_switches.htm
MINI ROCKER SWITCH LED ILLUMINATED
23mm diameter. Press into a 20mm hole. 5mm spade connections.
RED #RSR AMBER #RSA GREEN #RSG NEW!! BLUE #RSB
PRICE £3.00 each + P&P
yep same as mine which is red
The switch in my car is amber and it passes everytime, then again tho, my dads does'nt light up at all and it passes, LOL :D
mmmhhh my switch is in center console and dosent light up as far as im aware but the fog light works so hey !
