Knock sensor
What resistor is needed to do the bypass???
I know its a 1 ohm but 3w or 5w????
Not 1ohm, its 1 Megohm (1,000,000 ohm) , also displayed as 1MOhm.
1/2 watt is what the ones I use have written on them.
THats fantastic Snoop thanks very much.
Just hope it works?????
did you put it in the ecu end and not the sensor end Dave?? it needs to go to the ecu mate
yeah i did it in both just in case :(
those are 1 meg and work for other people mate..wrong plug maybe?? and anyway you still owe my daughter a packet of smarties ya selfish man ya:D
:rofl:
Its defo the right plug. but just in case i did 2 connetors and both sides and nothing???
could be a faulty resistor?
What else could cause the car to go into safty mode??
:rofl:
If resistor does not work then its likely a fault with the loom between connector and ECU.
Thats fantastic. how would i go about fixing that :(
Also this has only happend since i put the boost jets in
oooo fookin hell.
Pin 23 (presume white wire) what do i do with that :confused:
sorry to tag on but i need one of these resistors, thinking of going to maplin this evening.. but which one is it? the list in the link has like 50 variations!.. does it matter which one i buy?
Ive just picked up 5 of these from a local electronics place for 50p......
No idea if it works as resetting ecu at the mo, if it does, i will send you one FOC.
See thats me, nice guy ( or if your my ex wife that screws around then im not that nice, but its your fault)
I will let you know
STu
I will let you know
STu
bargain! cheers mate :) ..
p.s. im almost 100% sure im not your ex wife!
