Project Silver Streak 6 years on
Not sure where the right place to post this is, so I'll stick it in here and let the mods decide if it gets moved/deleted :).
I bought the car in October 2002. It looked very standard. It was infact completely standard.
It's come along way in six years and it's been off the road for over half of that time. It was after I had compression problems and had to have the valves reseated that I decided to start making some customised changes to it. £50k+ and 6 years later the car is "almost" exactly how I want it.
So what have I spent all the money and time on.....
The very first modification I did was traction control. It was my pride and joy and I didn't want to trash it. I decided to fit this myself. Didn't have aclue what I was doing but got there in the end.
TC16.jpg?t=12213333426
Next I decided to get rid of the orange side repeaters.
New.jpg?t=122133328
I never liked the tweed and covered it at an early stage, however I used vinyl rather than leather at this stage.
before
Interia2-small.jpg?t=1221333679
after
InteriorfromdriversT-bar-small.jpg?t=1221333692
I had the 60k service done by zedworld and had braided brake lines fitted along with new standard discs and pads.
I then fitted an apexi induction kit.
Next on the list was window tints. I got these done in a semi small guy buy at Paul C's Garage in kent. I decided to stay legal at the fronts but go limo on the back.
Tint06.jpg?t=1221334755
  • Replies 56
  • Views 3.1k
What do all good sports cars have ?. Red calipers (I thought).
so I painted them.
P1001546.jpg?t=1221334889
I played around a little for a few months doing the headlight mod so I can use UK bulbs, meshing the front bumper, fixing little things that were wrong etc.
I then started getting goose honk so fitted some HKS sql bovs in place of the recircs.
I'm not sure what possessed me at the time but I decided to go for a UK rear bumper with a lip. Sprayed and delivered by PPS.
P1001598.jpg?t=1221335222
I then got rid of all the orange at the front of my car by removing the orange lenses and replacing the bulbs with silvers.
Some more small changes over the next few months like gear stick knob, ali dash trim and some stupid arse boot build that looked ok ish but sounded really terrible.
I wanted to get rid of the road noise inside the car so I sound proffed everything.
before
ICE1_small.jpg?t=1221398424
during
ICE4_small.jpg?t=1221398280
ICE3_small.jpg?t=1221398259
I then added a front and rear strut bar.
strut009.jpg?t=1221335692
I pretty much encountered all the problems that so many people experience in the time of ownership...
Leaking fuel lines, causing petrol smell in the car, wet passenger footwell due to heater matrix, air leaks, oil leaks, pas leaks, burn out ptu, Problems with temp sensor, tps, maf, Hicas etc etc.
One of the first major problems I had was a burn out piston although at the time it was diagnosed as sticking Valves by Nissan SE as they were called at the time.
So while I was getting the heads skimmed, valves reseated and in the end a replacement number 6 piston, I also got a new clutch and a skimmed stock flywheel. I had the plenum and water pipes polished for a bit of bling.
June 2003 was the time I changed the look of the car. Booked myself in at PPS in Newcastle (300 miles away), didn't trust anyone else. At this stage I kept the rear bumper but deline and smooth it. I replaced the front with a stillen. I added a bonnet bulge and a high level rear spoiler along with Wings west skirts and delined doors. I also swap out the rear lights for 99 specs.
SMW1PPS7.jpg?t=1221335526
SMW1PPS9.jpg?t=1221335544
Had to get rid of the stock wheels and came into some R34GTR calipers as well, so new discs and pads to go on with the new wheels.
B0803033.jpg?t=1221335891
More small mods like new series 2 ptu, pcv vales, new temp sensor and new injecto and coil pack connectors.
I also decided to change the dials and fit chrome rings. I went for the indiglo ones.
dials3.jpg?t=1221336117
For the next big mod I got James(jaffa) to give me a hand. We upgraded the stock IC's with Greddy's, the rad with a Howe, Viscous fan with an electric, Underdrive pulley with a lightweight, stripped out loads of stuff I didn't need like AIV's etc. Painted the cam covers, changed the belts, added hard pipe boost hoses and rad hoses.
Some comparrison shot's...
Greddy IC's
mods007_small.jpg?t=1221397615
Oil cooler
mods009_small.jpg?t=1221397669
Howe Rad
mods017_small.jpg?t=1221397693
Underdrive pulley
mods021_small.jpg?t=1221397744
New electric fan
mods033_small.jpg?t=1221397829
This is the pile of old parts and parts no longer needed tat we were left with.
mods030_small.jpg?t=1221397783
This is what the car looked like once we were done
mods038_small.jpg?t=1221397844
mods039_small.jpg?t=1221397870
Next up was a replacement exhaust, I originally had a rusty greddy, but decided to get a powerflow made and fitted with decat test pipes.
Zorst1.jpg?t=1221421528
This exhaust lasted 2 months before I got bored with the sound of it. I decided to have a custom exhaust by an american company called pipecraft.
Unfortunately I don't have pictures of it so you have to wait a little longer.
Enjoying the car so much now and thinking what I can do ext to improve it to my taste even more.... but then it happened. I was parked outside a bank anda ford transit pull in to park in front of me and clipped the front of my car.
still1.jpg?t=1221421119
So another call to PPS who would give me an insurance quote below the others for sure. While the car was there I not only got a new wing and new stillen front bumper, I also decided to get IC side vents fitted and a new Wings West rear bumper, that was custom made and belnded to fit my new Exhausts. I also got the top pannels of the car (between windscreen and targa's and targa's and rear screen) painted black.
At the time a comapny called Ice works was working with PPS so I decided to get a new custom boot build done as well.
P1002605.jpg?t=1221421734
pps1.jpg?t=1221421832
P1002607.jpg?t=1221421791
We are now well into 2004 and wih Billing just around the corner I had to get the interior finsihed.
I ordered a katzkins set in dove grey and black with logo's stiched on the seats. Took me a while to fit this. I also ordered an extra hide of dove grey so I could trim the boot area.
before
seats001.jpg?t=1221398682
after
seats022.jpg?t=1221398729
seats035.jpg?t=1221422142
P1002936.jpg?t=1221422198
Still had to get the gear shift and handbrake gators done. But managed in time for Billing 04.
Billing 04 was great, I managed to get 2 first prize awards from 300zx.co.uk and one from Zclub.
some pics..
P1002957.jpg?t=1221422356
P1002956.jpg?t=1221422344
P1002954.jpg?t=1221422303
Unfortunately on the way back from billing. there was a little smoke, then a rattle, then no boost past 0. Yup the dreaded turbo's had gone.
I decided as I was driving home, I would go straight to my parent house and leave the car there (35 miles from my house).
I was now confident to swap them out myself. So a week later, I started work with a some help from Mark Hanley, MTL and mike Groves.
Engine out..
IMAGE_00024.jpg?t=1221422515
Started stripping..
IMAGE_00029.jpg?t=1221422575
IMAGE_00043.jpg?t=1221422592
I stripped it all down to the bare block to check for bore scratch as the passenger turbo wheel had grinded with the housing.
It was at this stage I decided to upgrade a few more bits. Weisco pistons, jwt530bb turbo's, nismo 555 injectors, rps max street clutch, billet flywheel, carbon single piece prop shaft, gred dupree manifolds, greg dupree downpipes and flexi pipes and much more.
I sourced all the parts along with another lot of 60k service items, new water pump, new gaskets, egr blanking kit, plus every thing else I needed for a rebuild, even a set of chromed headlights and clear rear side reflectors. If you are still reading this thread, I'm impressed, prove it and reply with the word stuffybum in you reply.
I used CMS is dagenham to bore the block for the new pistons and at the same time balance the crank, underdrive pulley and clutch/flywheel.
Driving 35 miles each weekend was getting painful, at the time a new garage called Zen opened up. I decided to get a guy called Martyn to finish the job.
Very long story short, it took him 3 year to get the job done, it nearly went to court.
Some pics from the engine build.
RPS Max Street/GD Downpipes
800.jpg?t=1221424958
in it's case
h2.jpg?t=1221425192
JWT 530bb's with HKS actuators and GD manifolds
a12.jpg?t=1221425002
HKS v Stock
a3.jpg?t=1221425069
Doolz Twin pop
dsa.jpg?t=1221425132
Reconditioning the lifters
e2.jpg?t=1221425160
GD Downpipes and flexi pipes
i6.jpg?t=1221425225
Chromed headlight conversion
j3.jpg?t=1221425255
Something to help with Camber.
c4.jpg?t=1221425097
Rebuild almost complete
j5.jpg?t=1221425285
This pretty much brings us up to the present day. I've had a two water leaks so far but found it to be a ceased rad cap. Just ordered a Greddy and have stripped and repolished / painted parts of the engine.
I got a few more bits I would like to do like, custom map from JD, tidy up any interior bits, get the wheels refurbed, then I'm done.
Edited by SMW1
So, from being completely standard the spec is now as follows:
Bodywork
Stillen GTZ-R2 front Bumper
I/C vents
Stillen Headlight Panel
Bonnet Bulge
Wings West Side Skirts
PPS Customised Rear Bumper
Delined Doors
Tailgate Skin
High Level Rear Spoiler
Colour coded wing mirror mounts
Blacked out roof strips
'99 spec rear tail lights
Illuminated centre panel
Clear Front indicators
Clear Side Repeaters
Chromed Headlights
Clear rear side lights
Tinted Windows (30% fronts, limo rears)
Wheels and Rubber
Black Chrome MasItaly 18" x 10.0 rears
Black Chrome MasItaly 18" x 8.5 fronts
Eagle F1 GSD2 245/40 x 18 fronts
Eagle F1 GSD2 265/35 x 18 rears
Exhaust
Pipecraft 2.5" straight through zorst
Greg Dupree flexi pipes
Chrome Back boxes with Quad 3.5" pipes
Greg Dupree Split Downpipes
Brakes & Suspension
R33 GTR Brembo Calipers
Portfield pads
Brembo 330mm discs
Rose jointed adjustable tension rods
SS braided Brake lines
Blitz Springs
Koni Shocks
Midori Front Upper A arms
Front Strut Bar
Rear Strut Bar
Transmision
RPS Max Street Clutch
RPS Billet flywheel
Carbon Fibre Prop
Billet Short Shifter
Engine
Weisco 88mm Forged pistons
Nismo 555 injectors
Greg Dupree manifold
Balanced Crank
Skimmed Heads & block
HKS SQL BOVS
Doolz Twin Pop with Apexi Cone filters
Unorthodox Underdrive pulley
JWT530BB turbo's
Cooling
Howe Rad
Greddy SMIC's
Uprated Oil Cooler
Viscous Fan replaced with Electric Rad fan
Electronics
RaceLogic Traction Control with Launch
Clifford AV4 alarm with inteli start & Blackjack
Blitz SBC-Id
Blitz Power-iD
Engine Bling
Polished Plenum
Polished Water pipes
Polished Coil Pack Brackets
Polished CAS
Polished Hicas
Custom upper and lower cam belt covers
SS Hare pipe hoses
SS Slam Panel (3 piece)
SS braided Fuel lines
SS Rad Pipes
4mm Blue Silicone hose replacement
6mm Blue Silicone hose replacement
SS braided Hose replacement
Custom Throttle cover
Smithy Chromed Large Fuse box cover
Custom Painted Small Fuse box cover
Custom Painted Balance Bar
Z1 Chrome rad bracket
Insane Oil Cap
Chrome Dip Stick
Chrome Brake Res Cap
Chrome Clutch Res Cap
Chrome Rad Cap
Chrome Rad Overflow Cap
Chrome Battery Tie Down
Polished PAS res
Chrome PAS Res Cap
Cockpit mods
Twin A pillar pod - awaiting gauges
Ali pedals
Brushed Ali interior kit
Custom interior Din switch panel
Custom centre pod
Custom Leather Seats
Leather interior trim
Custom Gear and Handbrake grips
Custom Steering Wheel
Indiglow dials
ICE
Complete door and rear dynamat soundproofing
Alpine cd head unit 4 x 60w
Kenwood 200w dual mag components
Door mounted illuminated crossovers
2 x 10" 1600w JBL subs
Kenwood 1000W mono sub amp
Kenwood Powerslide Amp
Neon Glow amp rack lights
Custom Boot Build with Leather Trim
Credits
Body Work was done by PPS.
Recent Engine build done by Martyn B.
Everything else on the car from Suspension, exhaust, engine mods, interior, bling etc was done by myself.
100_4444.jpg?t=1221425547
100_1788.jpg?t=1221425569
See my video on you tube, this tells the story beter than works can describe...
Silver Streak - The Story so far (video link)
Great thread buddy and some excellent work on the zed :D
Looking back you must be amazed what you've achieved over the years on it
Looking back I think I would have saved the money :)
Awsome work 'stuffybum'! I remember all the early stuff, my, haven't you been busy! Lovely car, and best of all ..... Silver:bow::dance::D
Blimey, I've just relived about 6 years of my (stuffybum) life !
Absolutely incredible! :bow: :bow: :bow: What a fantastic read! You've done good stuffybum :D :rofl:
And I googled 'stuffybum' and stuck it in the search box on the forum... and nada :slap:
but wow what a transformation :bow: Bet you are proud Mr Stuffybum :tongue: (after asking someone!!!)
Awesome car :bow:
remember seeing the vid on you tube its come a long way from standard thats for sure:dance:
and looks well nice !!! (stuffybum):D
to think im only on stage 1 of my mod list:cry:
My thoughts too...........
....nice one Stuart:D
Richard:dance:
Its fantasic looking at old pics and seeing how far you have come :duffer:
excellent write up, has come a long way stuffybum
