56 OHM resistor
anyone know where i can get hold of these, i need a few to slow my pc fan speeds down
it's been years since i've done electronics, would i need a bigger wattage as the fans are 1.8w 12v
Don't you have temp controlled fans ? Ought to be able to do it in software.
If not, you probably ought to go for a 2 or 3 watt resistor.
Edited by AndyP
I've got a fan speed comtroller but it only takes the 60mm fans down to 2400rpm from 4800rpm and the 80mm from 3200 to 1900 rpm
pc is water cooled so fans don't need to spin that fast
