Brake question
Can the brake set up dics a clalipers ect from the 350 fit the 300 if you have 18in wheels, or is it to much work?
Yep no probs if fitting both the discs and calipers from the 350z. Make sure you use the 350z caliper bolts (14mm) and to fit, you simply drill the zeds 12mm hole ( hub to caliper) to the 350z's 14mm.
Job done!
smithy
Front yes, back i believe is a bit more involved because of the hand brake set up. Not sure on the ins and outs tbh.
Pretty sure AndyP has done the rears so he could answer that best for yer. Don't know anyone else who's done the rears at the mo other than him.
smithy
