have searched various threads but cant seem to find how to locate engine & chassis numbers- would like to check age of my z32 import-
thanks in advance!!
thanks for comments- where is engine number stamped and how do I age the check age of car from vin number?
Have a look on the inside of one of the rear light inner covers, it should tell you there.
thanks for that leigh- I also need engine number as have read that early ones can have certain probs!!
The engine numner is stamped on the rear of the block at 12 o clock where the gearbox mates up to it.
If you send me a photo of the VIN plate I can usually identify the month the car was manufactured.
thanks for that snoopy- will look when i get home.
Andy- can't do pics- could I email engine number?
Chassis number would be better, its stamped on the VIN plate.
if you put the chassis number in here it will tell you the age of the car (if its an import from Japan!!)
http://www.japan-partner.com/check-manufacture-year.php
sory for hi-jack,
but my V5 says 4 owners.
is that this just this country?
or 45000 in japan, and then 4 in this country lol
sory for hi-jack,
it would be 4 since 1st registered in the UK.
thanks for that 300 girl- comes up 'no data held'- do you have to register etc to obtain the info?
Yep, chassis number then, will be something like GCZ32-555555
Andy
GCZ32 502236- thanks in anticipation- one seat belt is 1989 & one is 1990 btw
Chris
ok on it for you.
http://www.courtesyparts.com/specs/vin.html
only good if you have a VIN. If not, as like mine you can read the chasis number.
"G" in the chassis number indicates 2+2 variant; no "G" is the 2 seater SWB version. "C" indicates the twin turbo. "H" as you have already seen is the convertible. Thus there are Z32, GZ32, CZ32 and GCZ32 models as well as HZ32 in the Japanese domestic market.
your 2+2 1990
Edited by deve8uk
dave- only just spotted your post- how have you found mine to be a 1990 - expected 1989- any idea of the month??
