propshaft
is there a difference between a n/a and tt prop or are they the same cheers:confused:
i think they are the same BUT there is a difference between manual and auto. Im fairly sure that the rear part of the shaft is identical on all models, its just the front piece which is different on manuals and autos and on LWB and SWB.
They are completely different.
I believe an N/A is about 2in longer than a TT and the N/A is a 4 bolt flange compared to a TT's 5 or 6 ??
smithy
smithy
^^ Yep!
The Front differs between Manual and Auto. The rear Differs between SWB or LWB and TT or NA.
many thanx, anybody know where i can buy the center joint
New - Mike@MJP would probably be cheapest UK supplier on forum
Used - SWZ Parts
Both in traders section.
the shaft of the prop is also smaller diameter :)
