judder help
i seem to have a few issues with my car, if you accelerate hard you get a judder :rant: also there is a droneing noise after around 45mph. i've changed the auto gearbox mount (came off in 2 pieces) and done the rear subframe mounts but its still there, :headvswal any ideas
Ref: the droaning
wheel bearing?
Diff?
Edited by wow300
checked wheel bearings all ok, my thoughts go towards the prop as the gearbox mount and rear subframe mounts were knacked but would this cause a drone?
Does this sound go when going over say 60 mph? then it is possible it is the propshaft bearing.
when it happens, does the steering wheel judder? then look at wheel balancing,
if it is continuos might be worth checking engine mounts/ prop.
