Boost
got my AVC-r up and running, I've got the highest boost reading 1.15km/cm2
Can anyone tell me what that is in Psi and if it is measurement for Bar? Also what BHP it might be?
Yes their standard
Better turn it down a bit, couldn't find a way of changing the readings. Also have it in km as I cant change that either
One of the buttons on the front ( left i think) you press changes the reading configuration, i think the 2nd push puts it in PSI, much easier :D
smithy
Would that be about 14 psi?
what would the bhp of been when running at just over 16Psi?
on standard injectors and turbos, it wouldnt have been much more than at 14psi as everything would be maxed out. in fact youre probably producing fewer horses at 16psi than at 15psi - and also wearing some components out faster. at 14.5psi with your mods you are probably pushing out something like 360-370 at the flywheel. just an estimate.
I was aiming for 14Psi, I set it up from the twinturbo.net install. was set at 58%, any idea what to set it up to next?
i made 364 @ 9psi na-na nana naaa! :tongue:
14 / 14.22 = 0.98km/cm2
