Driver's side window not working...
Hi there,
My driver's side window has stopped working. Could anyone tell me where the fuse is for this please?
I've found the fuse for the passenger side (but that works) - is there one for the drivers side?
I hope it's not the window motor (again)
Mr Pink
Mine did this, turned out to be the amplifier had been crushed when the window went down, took the window out 2x 10mm nuts and then managed to get hand in to get the little black box out, then taped it to the door...
never happened again :D hope this helps
Alot of the time the little black box behind the door card has a dry joint. Undo the door card at the bottom and pry it away carefully, you can then get your hand in there and unplug the little black box. Open it up and look fro dry joints, whack a bit of solder on any you find, and you may find that sorts your problem :) I've changed a motor before finding that out and it still is'nt funny ;)
Hi there, thanks very much for your replies. I had the door card off this morning and found the amplifier, unplugged it - couldn't figure out how to get into it, plugged it in again and the window worked.
Put the door card back on and found the window didn't work.
Took the door card off again and unplugged the amplifier and plugged it back in and it worked. Tried wiggling all the cables to see if I could find a loose connection but it was fine.
Put the door card back on and the window now still works!
There must be a reason but I can't see it, so I'm a bit confused, but at least it is working for now! Thanks again for your help.
Mr Pink
i'd get a replacement amp if you aint into circuit repairing / soldering....mine did all sorts of weird things working then not...getting stuck etc etc
Paul @ SWZ is stripping a few cars...check the traders section....dead easy to get one posted out
Mr Pink
the reason is when you wiggle it the dry joint on the circuit board inside makes contact for a while. and it WILL fail again and possibly in the most inconvieniant time like you just travelled 20 miles tgo go shopping , pulled into a multi story carpark spent 15 mins finding a space , go to do up the window and find it wont!!!!!!!!
trust me i have been there!!
take out the black box , gently open it up and run a soldering iron over all the joints on the circuit board!! i did it and it has never missed a beat in 3 years.
There is a little button on the drivers side power window switches, make sure u haven't depressed that as it stops the passenger window working!
Mine did this took the window control box out removed the circuit board and sprayed electrical contact cleaner on the switches worked fine since.
Sound Advice IMO :)
Gently open it up? I always worry when I have to do things 'gently', as it usually means 'break it'. I'll muster the courage to do it - or I'll get a second hand one!
Thanks to all for your help and advice!
Mr Pink
