Hello all! my TT has been running like a bag of nails for a while now I have checked everything I can but all fine, ran ECU test and Im sure a different code came up first? like 34 or 43?? but then code 55 and stayed code 55 after that! the idle is lumpy going up and down from 400-900rpm sometimes cuts out, I can smell fuel at times but no fuel leaks. I cleaned every connector I could see with most of them with blue corrosion on but no change so I took connector off TPS which was dirty so cleaned it up and now im sure the zed runs worse, even more lumpy? So could this be a dodgy TPS?? Can it be adjusted?? I dont want to pay for a consult if I can help it but I have checked everything. If anyone can help that would be great!!
