leaking subframe bush
collars can usually help, but on the subframe I would suggest replacement. There's a lot of weight that sits on that baby !
would be looking to get all the rear bushes replaced at some point but have other priorities at the mo so just looking for a temp fix in the meantime then reuse the collars with new bushes to firm things up if yo know what i mean
Yup collars would work in that case then until you are ready.
I'm not sure if subframe bush leak is MOT failure though, you'll have to check that. It's usually just gators and the like, but you never know.
would collars work with a leaky bush or is it a deffo relpacement job ta
One of these usually does the trick!
:rofl:i wondered how long it would take:rofl:
