the indicators on the passenger side all work BUT are flashing really fast!:confused: WHATS WRONG?:(
dan.:(
As above or one of your indicator bulbs (could be any of them) is blown and requires replacing.
Dan
thanks for replies!:dance:
the drivers side all work and flash normally, the passenger side all flash and work but flash twice as fast as normally!:confused: will try wiggling the hazard switch and see what happens.
thanks.
dan.
make sure the bulbs are the correct offset pins as bulbs with the wrong offset pins still seem to fit but make the bulbs flash fast.
ok tried wiggling hazzard, all indicators work on hazard at normal speed, all indicators work on drivers side at normal speed, put on passengers side and they flash twice as fast, noticed the pass side ind bulb dull so changed over bulbs and its the same dull so thinking perhaps earth problem!:confused:
dan.:(
FOUND THE PROBLEM! its the actual indicator unit at fault, when changed over it happens on the other side, so after a set of clear lens indicators for a 1990 jap import. ANYONE?:D
dan.;)
