What is this little box under the ECU?
I took the passenger side kick panel off to gain access in running a power cable through the bulkhead. Now I noticed something that I haven't noticed before, the little silver box next to the ECU wasn't connected to th plug that's dangling below it.
Can anyone tell me what this is and why it may have been disconnected?
  • Replies 46
  • Views 2k
is that the 99 spec plug :x: sorry Si i could'nt resist, someone will be along shortly with the right answer :D
that looks like the gearbox ecu mate
I thought only autos had ECUs?
yours might of been an auto to begin with Si, ive had a j-spec man which was converted 2 years into its life
...suprised Gio didn't pick up on that when we first went to view the car as we had a lot of the panelwork out to check for manufacture dates/spec levels etc.
try a vin number check and see what it was made as..
Its the BS intensity regulator.
Mine hasnt got one which is why I speak a load of BS at times. Its a common feature in Japanese cars and a lot of them have been removed or disconnected. :D
The Autobox ECU is not in that pic, and it has a Blue connector similar to the Main ECU connector.
:confused:
:confused:
They regulate the amount of Bull Shite you talk about your cars performance and spec. :rofl:
dont bin it, find out what it is and sell it
Had a look in the manual.
Attached a copy of the compartment electrics location.
Darrell
Thanks for that, but for some reason, I can't get it to download.
Thanks Jaz. So it is an auto-transmission ECU judging by that photo. Can anyone confirm?
its not that i dont think does it have a blue connector
Nope, see the little black connector beneath it? That's the only thing I can see that would marry up with it and it's routed as such.
I can confirm its NOT the auto-transmission ECU ! The Auto ECU would sit over the top of that box. The 2 screw holes on the left and the 1 at the bottom is for the autobox ecu bracket.
you need the top half of that picture jazzy posted, as the arrow goes up off the top of the page in that diagram for the box you want
got it from the PDF....hmmm PAS control for NA ....that dont make sense
