trouble with the zed again...
Ok as you might know.... i have had a few troubles with the zed recently....
well... its starts up fine now.... good news... bad new the revs are ALL over the place...
doesn't idle proper and the revs are up n down and cuts out...
I was driving it and it just cut out!!! died on me...! but luckily i wasn't going fast and there were no cars around.... parked up safely....
Noe it does start but the revs just jump up and down... and the accelerator pedal just doesn't seem to control the revs?
it has a mind of its own? revs really low then finally cuts out... doesn't drive?
Looking for some advice because now the car is MILES from my home parked in a random street.
:cry: once i sort the zed i got a feeling its just got to go, annoying me now :confused:
water temp sensor maybe, take it out and clean it, start with the easy things first.
I'm off to see the car in hour or so... any more advice? cos the revs fly all over the place and the accelerator pedal doesn't seem to grasp the revs? weird to explain but usually u press the pedal the revs go higher.... u let go they settle down, now it doesn't nothing as if it has a mind of its own? anyone got any more ideas? wanna get it home :(
had similar when I inadvertantly left MAF unplugged but would also suggest temp sender connection.
Hope you sort it mate.
i will check the MAF because i did disconnect when i did the dump valves and i didn't drive it for a few weeks after i fitted them... but i am sure i plugged it back in.... will check thou thanks for the tip
i reckon it the cas? does it smell rich and when you touch the throttle cough splutters revs hit rock bottom and dies?
yeah it does sound how u described... so CAS then?
Throttle position sensor,
thanks, i will look for somey links to how i would go about checking this... thanks
