Brakes
Hi Again,
Taking my car to the Nurburgring soon and wanted to replace the brake pads on the car before i go, which pads take most wear on a trip like that (front or rear) or is it a 50/50 split as want to put the more expensive pad one the area that is going to do most work and cheaper ones on the other area. cheers
ps- should i get some new disks too, planning to do 8-12 laps over 2 days and drive there and back.
Fronts, about 70-80% Do you have stock sized brakes...if so, your going to suffer massive brake fade on the ring !
yeh, gonna have to take it really easy i know, just boot it on the straights and pray in the corners!! cheers though
when you say stocked sized, i have grooved disks front and back but stock calipers. can anybody reccomend any pads that would suit best for trip.
Hi Again,
you better put a spare set in the boot mate :x:
thats all in for 4 pads and front and rear disks, would only offer 300 and would collect. good advice bout the pads though, cheers
For that sort of money you can get a Big brake conversion, consisting of Bigger discs, and brackets to re-space the standard calipers. That will make a very noticable difference in braking.
where from, and also will they work with the standard z 16" wheels as i don't really fancy taking my 19" TSW's, £110 Per Tyre.
ah...no, you need 17"+
You'll have to stick with the standard sized brakes. Check out http://www.smithys-place.co.uk for brake options within the UK.
