February 12, 200818 yr could someone (andyduff) guide me through removing the passenger engine mount in situ as i had a look at it this morning and thought WOW thats tight, looks like theres no way to get to the top bolt? what has to be removed? thanks guys.
February 12, 200818 yr Bloody hell give us a chance lol :D It IS possible, just fiddly! You may need to cut a spanner down in order to get to the top nut, 14mm btw :)
February 12, 200818 yr Author damn, so i need a tiny spanner for the top. isnt it gunu be too tight to undo? any tips?
February 12, 200818 yr Yep could well be tight lol. Thinking about it, depending on what tools you have you MAY be better removing the entire engine mount assembly from the block and doing it that way. The bolts attaching the alloy mount to the block are also 14mm... Be very carefull though that you don't crack the oil feed line to the passenger turbo if doing it that way - its secured at the pressure sender via one of the mount bolts...
February 12, 200818 yr Author but you cant get to them bolts either or can you? how many bolts are there on the bracket? as i remember seeing them from looking behine the engine, is there one more bolt infront that i cant see? i have a good set of tools.
February 12, 200818 yr If you have a decent selection then try and just remove the rubber mount. The alloy mount has 4 bolts on it in a pretty much square pattern....
February 12, 200818 yr Author ok thanks andy. one more thing how much should i jack the engine up to remove it?
February 12, 200818 yr Enough to get it out lol. I would slacken the drivers side mount a bit though to give some extra movement so you don't tear that one
thanks guys.
