Indicator Relay
On the way into work this morning my indicators packed up on me, I found the fuse box that had about ten relays but no sign of the indicator relay, could someone kindly point me in the right direction.
Dammit!
[This message has been edited by AndyP (edited 29-07-2002).]
Andy
Thanks for the help, where abouts by me feet is it, as I can't get down to have a look.
There is a plastic kick panel to the right of the accelerator - they're behind there.
this happened to me the other week, one thing to check is the hazzard light switch, if its not sitting in the right place then the indicators dont work, that is what the problem was with mine. the posts that hold the switch in position on mine have broke, hence why im after a spare air con pod if anyones got one.
worth checking it out though if your fuse is ok.
do a search on the forum, thats what i did , i wouldnt have dreamed of checking the hazzard switch otherwise
Scoops
Thanks for the tip, tried it and my indicators now work
