it still wont turn off
just been out to start the zed ( shes off the road till i tax her on friday ) and the old problem is still there
when i turn the ignition key off and remove it the engine still runs till i press the accelerator pedal . this is now really beginning to get on my tits
ive changed the ignition barrel and had a diagnostic check and its NOT got a turbo timer on it cos sometimes if i leave it she will run for a couple of minutes and then stall and yet sometimes she will run on for ages until i press the pedal
pleeeeease someone must know what it could be
any advise will be appreciated
matty
Ask Andy About That Mine Did That A Little Bit Too, Do You Have A Turbo Timer?
Wonder if it could be a faulty ECU? Maybe an alarm issue holding the ignition on? And he said NO turbo timer Saz :p LOL ;)
ah i se i can only glance through at work have to watch out for gaffers
so i need another ecu to check it and see if thats the problem cheers guys and gals
I would put money on it being the ecu. My old zed was doing this and a change of ecu cured it. I think it may have been caused by jump starting the car, but could never prove it.
Gareth
Gareth
nice 1 mate cheers
