has anyone fitted a greedy eo1 boost controller to there z32 if so i was woundering which wire you use on the ecu i`ve got someone coming to fit it on friday(18/01) :hyper: and wanted to provide as much info as possible.
To fit an E-01 you dont technically need to use anything from the ECU. There is one function of an E-01 that requires an RPM feed but it all depends if you are going to use that function or not. For basic boost controlling its a stand alone application.
I've got RPM and Speed (requires additional harness) hooked up on mine (although Speed is in KMH not MPH) and the line graph looks good :D
Im sure I can find the pin-out from the ECU that you need for RPM if you want it. Or you could do a search for E-01 and i am sure you will find the info you need.
Can you find the speed wire too, as ive got the harness but never been arsed to put it on yet!
thats great thanks,the so called expert came last friday and basically didn`t have a clue what was going on?(and still tried to charge me for an hour of his time!twat)can anyone tell me were the boost pipes are for me to plum into for the pressure valve and the solenoid
John dixon fitted mine, hes the best guy to ask.
I fitted one to a gto a while ago and it was a piece of cake compared to the zed, on the zed you need lots of Y pieces and extra hose.
