engine miss
:confused: hi chaps i have a miss on my t/t on the left bank of cylinders have changed the ptu but ha made no diffrence could someone give me some ideas thanks
All of them?
Have you checked the coil packs and the spark plugs
Just unplug injector, clean off the green gunk, then try it.
Do a search, missfires are very common.
mine did this intermittantly at first, then had a dead cylinder. turned out to be a fecked injector. good luck!
:hyper: i have new coil pack leads and injector wiers to fit bu this miss does not affect the way she flyes are injectors a pain to change
If its just the connectors its not too bad, if its the fuel rail, then plenium will have to come off.
