instrument cluster lights
when i switch my head lights on (which work fine) my clocks dont light up and the numbers for the air con on the left hand side go really dim i can only just see them is this something as easy as a fuse or is it more complicated than that, i did have to put the booster pack on it to start it today cos she aint been used for 2 weeks, if it is just a fuse could you point out which 1 it is thanks in advance, Chris. :confused:
Have you tried the dimmer switch on the right hand pod just in case it,s been fully dimmed :confused:
yep tried it and no joy
anybody, please?
The clock and Aircon display are meant to dim with the lights on, thats normal, so they are not too bright for the Night. Although if the clock dims so much that you cant see it then it needs replacing or repair, common problem.
yeah i can't see it at all i had to drive to work this morning at a guess on how fast i was going, is there any threads on how to repair it anywhere or is it just a fuse cos like said its only since i put the booster pack on it?
ahhh I thougth you mean the Time clock....no the Speedo clocks shouldn't dim that should light up properly...I dont think there is a seperate fuse for those lights...it has 4 501 bulbs in the back
would they all go at the same time though? it was just a sudden thing, i put the booster pack on to start it, (which is why i thought it was a fuse) then when it started to lash down with rain i put the headlights on and my air con display went off and the speedo clocks did'nt light up
a boost starter only starts the car , it doesnt charge a flat battery. once started the alternator will charge the battery to some extent but only if there is not to much else using the battery.
driving around with your lights / heating / stereo / back window demist switched on will not give it a chance to charge properly. as the battery runs out , it's voltage drops and things dim.
asuming your alternator is working i would try giving the battery a good charge and see if that helps. or measuring the battery voltage before starting, whilst running and with headlights on
[sIGPIC][/sIGPIC]
had the battery tested and its fine altenator is fine its charging as it should i'm gonna have a look at the fuses at dinner time and i'll let ya know how i get on, cheers all.
no joy with fuses, they all seem fine so i'm stuck for idea's so any help is really appreciated. :(
faulty time control unit maybe ???? does your interior light work ?
yeah interior light works
I know it sounds obvious, but the same happened to me and it was the dimmer. Just wondering if your dimmer adjustment is definitely working :confused:
Steve :)
'93 UK TT Manual
well a few people have said that but how do you check this or do you just have to swap them over and hope for the best cos i'm gettin ready to pull my hair out, i know its only a small thing but its really starting to annoy cos i go TO work when its dark and i come FROM work when its dark so i cant see how fast i'm going.
spoke to andy duff today and he thinks the same and he might have a spare 1 so hopefily thats all it is, and its not really a big job, which is always a bonus :rofl:
yeah thats the 1 mate, i've just bought 1 off andy duff so it should be done by the weekend, thanks for your help, regards Chris.
i have a spair right hand side control unit with the head lights fog and dimer if thats the prob then u can have it :)
thanks for the offer jimmy but its the control unit that sits behind the kick panel near the fuse box, get subscribed and put it in the for sale section, someone will buy it, cheers for that, regards, Chris.
All sorted :dance: :D It was indeed the time control unit :D
cheers andy your a star. :D
chris, did you get a new battery on the car?
Glad andy came to the rescue . . . Again lol, top man
Membership No 0780
INSURANCE GOOFA
nah the battery turned out to be ok, had it tested at work, it was just the altenator belt that needed adjusting, 5 min job, thanks for givin me his number Lee. :bow:
