help on stage 3 chip
need help ive had a stage 3 chip fitted to ecu
the fan is running constant and its overfueling really bad is there something i have to do to the car or is it the chip
chip sounds corrupt mate
Yep, sounds like it to me. Fan could also be due to your temp sensor being disconnected/faulty, which could also affect fueling.
Hmmm, a chip that will run right with either 370 or 440cc injectors - I doubt that. And a variable pressure fuel regulator won't help much - unless you turn it down ....
my fan always spins, is it fooked?????
If it's the electric one, then it could be your temp sensor.
are we talking about the fan behind the rad (as you are looking in the engine bay), it does get faster if it gets hot, it just seems to run all the time
this is like the chip ive installed and dont seem to be having any joy theres another site with a chip which says atmel on the chip which i am going to give a try will post thread when fitted if any good
in my experiance stay away from the chips with paper labels and chips with a clear circle in the middle.
are you talking about the viscous fan?, if you are, if does run all the time. If your talking about the auxilary fan on the rad, then the temp sensor is up the creak, are at very least a very poor connection.
