Battery keeps draining overnight!!
Guys
Have a slight prob with the battery being drained right down to nothing overnight, Happened last week twice so I thought it must be the battery and got a new bosch one put on. It's doing the same though. I have tried leaving the alarm turned off etc but it still dies overnight.
Anyone know of any usual faults with the electrics or ways to see what is draining the battery??
This sort of problem is a right b*****d to sort. What I have done in the past is with the battery fully charged and installed in the car, disconnect the positive lead and lift from the terminal. Touch it back on to the terminal and it should spark if any current is being discharged although everything is supposed to be off. What you do then is whilst repeatedly touching the terminal with the battery lead, also touch the relays to see if any are clicking, vibrating etc,. which means they are being energised and probably faulty. If no success here, remove the fuses, one by one, in between touching the battery lead back on the terminal, if it suddenly stops sparking you have found the circuit causing the drain. Its a long process but well worth it before you take it to an auto electrician and get a bill.
it may sound totally dumb but make sure the light in the glove box and allso the boot arnt staying on ;)
Yeah my boot light comes on when bonnet is open so goes flat at shows! I added a switch on the bonnet stick switch thing to turn it off.
Also check your headunit, leaving the facia on can drain it?
what you could do is put a voltmeter on the battery etc and pull the fuses one by one, the voltage should go up slightly when you remove a fuse from a circuit that is draining power.
Ideally, you want to measure the current, not the voltage, that way it will be far more obvious when you identify the culprit.
true but the fact its going down over night shows its drawing volts as opposed to slight current drain iff you know what i mean,and dont say "but its 12 volts anyway" :D
Guys
Put meter on it mesure the current if its drawing any amps start with the
obverse then start taking the fuses out if no joy then start with relays.If you have no joy PM me
Depends on the age of the battery, some are only garaunteed for a year, some 3 years, you could have a naff battery with dead cells, i just had the same problem with my 05 iveco, not being run enough during daylight hours and cold nights can kill a duff battery, just a thought
Check the fuse box in the drivers footwell for signs of water damage - its that time of year again....
Cheers all, looks like I will be enjoying an evening stuck in the footwell then lol...
I charged the battery up full last might but left it disconnected from the car afterwards. If it's a duff battery (no pun intended Andy lol) will it still lose charge with nothing connected?? Maybe not much but it should lose a bit shouldn't it??
Yes it will lose charge if Battery is Knackered, and this time of year is when a dying battery is more likely to show up.
Cold and Dark nights I would bet Diamonds its the Battery
Yeah batteries hate the dark dont they :rofl: :D
Battery has already been changed for a sparkley new Bosch one!! Hasn't lost any charge overnight though, time to start checking the fuses me thinks!! joy of joys :)
If you need a hand bud, just let me know, im only in Hook.
Cheers Nick, appreciated!! Do you drive a black Zed by any chance? I work in Hook and have seen one going out towards the motorway a few times now..
Great link retro!!
Great link retro!!
No mate, i sold my zed about 2 years ago. But i have seen the black one about.
Im off work till friday, so im available till then. Let me know fella
And youo havn't been drawn back yet lol, doing well!!
Looks like that could be a duff battery too, seemed alright yesterday but tested the levels again today and it's down to 10% so I'm gonna get another first and see what happens
