HKS SSQV on high boost
Hi!
Does anybody run with the HKS SSQV bovs on high boost?(2 bar)
Ive heard som roumers that they cant release the pressure quick enough...Doesnt match what HKS says about their bovs, but what do I know....
waiting...........
for a post from Funkysi (with a due sense of exhaustion and dread :rofl: )
but seriously if anyone knows I would be interested to hear it as well
To run two bar on a zed would be exceptional, the turbos would not last long and neither would the engine. But the HKS bov's are reputed not to be the best and have had rumours of them leaking boost!
They sound like this
This guy is running 25psi.. not sure if their releasing the pressure quick enough but it sounds damn nice ;).
The turbos and engine is built for that boost.. :hyper:
I have the SSQVs now on my 420RWHP engine, and they work well on 1,3 bar.
My main issue is, will they work on a higher boost.....? :confused:
Not much worth spending lots of cash on other parts, when the bovs can cause trouble.....
To be truthful the only thing I found hks to be good at making were turbos, I would get a set of blitz bovs or uprated recircs if I were you?
Give us your full spec then stop hiding it :)
i think its one of the Greddy range of BOV's Either the Type R / Type RS.. and usually with a big single turbo to get that noise ;).
thats exactly the noise i speak of! what does one need to achieve such wierdness?
Mine sound VERY VERY similair to that. I had a look and I'm not sure they're anything special, just silver aluminium piston type which are in place of the stock recircs.
Maybe I go for the Blits bovs, have been dravling over those... :smw:
The engine is a complete stage 5 engine from/built by Importpartspro in the states,With Wiseco pistons, Eagle rods, Ferrera oversize valves, JWT 500 cams, ported inntake and exhaust, valve job, balanced crank, ceramic coated bearings and pistons, cometic head gasket, ARP studs etc....
Garrett GT725R, JWT Manifolds,3" div.flange dps, 3"testpipes, 2,5"stainless exhaust with oval mufflers, 58mm throttle bodies, Greddy BIG ic, SARD 850cc, Sard Racing fpr, Nismo fuelrail, 2x Walbro 255L/H fuel pumps, AEM ems,......
My winter project :hyper:
What are you going to have to monitor this monster build?
Wideband
EGT
Charge temp?
record it and post it up ;)
Let me get rid of the crap fuel thats in there at the mo and I'll do it ;)
my s14a used to make same sound back though the filter!
I believe that noise is the turbo impellers chopping up the air when you come off boost. it does this because there is no way for the air to escape.
If you have a dunp valve or recirc you will not get this noise.
It is also not good for the car...
aahhh but your wrong... :shock: i had a bump valve as well but the car dumped after 4500+ rpm and chatted below.......
Hmmmm... back to the drawing board!
Wideband
EGT
Charge temp?
Im gonna use the AEM for all its worth.
1x wideband sensor
2xegt sensor
1xoil temp
1xoil pressure
1xwater temp
1xair temp
fuel pressure
3,5bar map sens
boost sensor
This will be monitored over 2 or 3 gauges, with warning set for all channels...
