Down Pipe And De Cats ?
hi i have bought some down pipes and de cats off a friend for my twin turbo lwb and i have looked under the car and there are two silver wires and two littler pipes (like lamba sensers ) i think goin to the standard down pipes.. the decats dont have places for these to go to so what do i do with them?
will i get any engine check lights on by removing the cats?
cheers
  • Replies 33
  • Views 975
sound like the 02 sensors mate. he replacement downpipes shoud have threaded holes for them.
are right ...... i have not recieved the down pipes yet but my friend i bought them off cant remember if they had the hole 4 them....... i shall check this out......
but that about the two thick silver wires that go to the down pipes or decats
cheers
Are these the 2 braided steel wires that come from the ducting to the exhaust pipes just after the gear box. If so then you just cut them as the are to do with your emissions rubbish. The Lambas fit into the down pipes and must be retained.
yes there the ones. so just get rid.........
thank you guys, what sort of gain am i lokking for with down pipes and de cats?
You'll feel the difference though you will loose a little low end torque. It will rev more freely and they estimate between 15 and 25 RWHP which is quite a kick.
sorry got mixed up with lamba sesnors r these in the back of the turbo elbows? the tubes i'm thinking of r the egr (exhaust gas regulators) what do i do with these?
Ideally the EGR valve wants removing and the boss on the manifold blocking off, but for now just block the pipes off. As the other is a plenum off job. Duffer recon's that the 22mm Yorkshire fitting pipe end stops fit in and that the solder seam keeps it air tight once the collors are tweeked tight.
ah the good old egr, i hate that thing. took me ages to get that out with engine in the car but plenum of.
so will these work temp or perminant as really dnt wanna take plenum off?
Yes just blocking off will work perminantly. Just if you get the plenum off then you can block it off from the manifold and remove all the valves and pipes and rubbish that sits in the wheel arches and back of engine. There is a fair bit of weight there.
Remember less weight = more bhp per ton
lol u dont need to tell me about weight reduction lol after i crashed my s14a the 300+ engine went into an s13 which i built in to a drift car.....this is weight reduction!
riceys009.jpg[/img]
riceys013.jpg[/img]
to say it was quick as a UNDER STATEMENT :D
riceys008.jpg[/img]
riceys009.jpg[/img]
riceys013.jpg[/img]
Lol Sorry About The Double Post
Yep but that doen't half fubar your Hi Fi Sound.
How ya doing Mr ricey :D
You will have to pop round with your Z, hows the gear box going ?, my engine is coming out in a week or 2 and I have a spare z block if you want to see where things are and what you don't need
:hyper: hello fry.... so you got my text then?
the gear box has gave up after just 2 weeks of ownership...
there is one on the sale section but i cant post on it ahhhhhhh!
so frustratin!
hows the car going ? quickly i hope :D
is there owt wrong with that block? I need something to rebuild without taking my car off the road :D
Turbo oil seals just about gone, if your round before the engine is pulled I will take you out and you tell me if you think its quick.
Does your zed drive ? do you not fancy a manual swap ??
are liam...... you should of asked me might of got it cheaper!......... fry's my friend lol
dont surpose you have anothe box for me eh fry.... you no how much you lik supplyin them to me!
if you lik i could show liam were you based matey?
Nothing wrong with the block I am keeping it for a spare though for when mine blows and it will
