November 3, 200718 yr Do any of you guys have a one piece propshaft fitted to your zed or know anything about them ? My centre prop bearing is on its way out and dont know if i should buy the new bearing or go for a one piece prop. What should i do? Also can anyone recomend where to get a one piece prop from if that i the route i should take. Thanks Matt
November 3, 200718 yr I fitted one, it was'nt too bad to fit. I still have the original vibration I had before the cx so either I didnt replace the right thing or I have introduced some new vibes however the prop is running true as I have used a DTI on it. Retrospectively, unless you desperately need to reduce weight cos your racing, I would stick to original set up as it compensates more for misallignment between gearbox and diff.
What should i do?
Matt
