In memory of Mandy
Engine tap
My engine has a slight tap when you first start it and then goes away when it warms up. Does anyone know if this is commen and what it is? Cheers
from experience a fair proportion of vg30's do this ( soft tap tap tap from the top of the engine ) , so if its not too loud and it settles down , I wouldnt worry
hydro lifters (tappets) bleed down overnight and they take a min or 2 to pump up again, dont worry ;)
Ye id go for hydro lifters to, especially if the car is not used regular
I use my car regularly and the tap is loud at times, comes and goes. Should I be worried???
only iff the wife keeps telling you she,s working late and coming home with her draws inside out :D
