Steering wheel airbag light
My mate has just removed and replaced his steering wheel (to correct positioning) and now the airbag light is on / flashing. Does anyone know why this would be please, is there something that he missed.
Car is a 93 TT J spec auto TT so no cruise controll or anything on the wheel.
Thanks in advance
Thanks in advance
tell him to give uxb services a call and stand behind a wall ;)
If he has taken off the airbag wheel then chances are he will have to have the light reset im afraid !
ย
Hi Paul.
It's Mike that you spoke to abou the other car. He removed the steering wheel as it was put on wrong when he had it re-covered, wasn't straight. He put it back on in the corect position and now the light is on :( .
Do you reckon this will need re-setting mate ?
Phil.
Hi Paul.
Phil.
ย
Got the reciept ok by the way mate :)
Hi Paul.
Phil.
If the air bag was disconnected from the clockspring then yes,if it was left connected chances are the clockspring(contact ring)was damaged!
Only know if you plug it in I'm afraid! :)
cant you just remove the bulb? :rolleyes:
PMSL!-you can but the airbag won't operate! :wack:
It needs to be plugged into the Nissan software to be reset.(don't know if consult/datascan will do it?)-bear in mind if there is a fault the light will remain/come back on!
ย
ย
GREAT the postal service is crap at the moment !
ย
Unfortunately mate yes
ย
Er no it doesn't. You can reset the air bag light by using the drivers door switch see here http://twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=896169&words=air%3a%3abag%3a%3alight for the know how
Ooooo...handy to know!-I'm going by most modern systems here so forgive me!:rolleyes:
ย
Your forgiven :D :rofl:
ย
It one of the nice thing about a 300zx, a mate of mine had to shell out ยฃ80 to have his air bag light reset on his Audi, then was pig sick when I reset mine with the drivers door switch :rofl:
