uvpc french door advice from window/door installers
i bought a french door from b/q at a stupid price (ex display) but it came with no keys and with it being locked i had to drill the lock open so i need advice from any window/door installers where can i buy a new lock set from ???? the type that runs the full height of the door with the latchers and roller pins. i only need the lock side so are they a standed fitting or do i need the "keep" side as a matching pair
could you not just replace the barrel ? or is it different. any pics ?. on my pvc french doors the barrel can just be replaced.
i would ask greg he is a locksmith!
I'm a window fitter.
You just need to replace the barrell, if you've drilled it, can you
get a screwdriver in there & turn it to operate it?
If so, turn it slightly off-centre, the barrell will then slide out once
you've undone the retaining screw, which runs from the edge of the
door into the lock barrell.
If you still can't get the barrell to work after drilling it, remove the handles
and attach a pair of molegrips to the 20mm or so thats sticking out of the
door, and snap the barrell (very easy, they are very weak where the screw
holds them in), then remove the barrell.
If you've got any pics, put 'em up.
no i had to lets say "persuade it firmily" to come out and damaged the lock itself :headvswal
lol, i can get u a lock for nowt, can just pinch one from the factory :x:
Probably have to be both sides as the cams may not line up properley.
Wherabouts are you?
the problem was the doors where locked so could,nt get to the retaining screw thats why i had to fvk it up proper to get the door open and the whole locking mec is gone bad,its the type that has roller pins top and bottom plus the mortice
Wherabouts are you?
wirral near chester bud
its a shame the locks damaged. i could have also got you a free barrel with keys :rolleyes:
Got a feeling our lock's not gonna fit that mate, ours are a lot
'chunkier' than that one, plus you'd probably have to modify the
doors to accept it too, and as they look like woodgrain ones, they will have lots of metal inside them, i'll swag one from the factory tomorrow anyway
and take some pics with some dimensions.
Has the lock got a manufacturer's name on it, could try googling it, they
may do replacements, can b&q help at all?
thanks for the help mate,ile try b&q tomorrow :)
and thanks for all other replys guys :bow:
