Fitted Decat pipes and split downpipes!
Hi,
Have just fitted the split downpipes and decat pipes from 2fast2cool on ebay and I have to say I am very impressed!
The fit is spot on, and the performance improvement is great, the turbos spool earlier and boost lasts longer through the rev range, they are worth every penny which wasn't much to start with!
Would these fit a UK car though?
Wish I had some but dont want to take the seal test, lol
Ive had stuff from 2fast2cool before and quality was good.
iv used there stuff before and have always been impressed TBH
I am pretty sure they will fit a uk car, I have never heard of any issues!
have got there decat and divorced down pipes,great product guys and wood highly recommend :) .
cheers garry
he is a good bloke and is easy to deal with. The quality of his stuff is very good and comes very quickly.
Didn't know you knew him so well :smash:
what about the turbo seals which im always been told will go if i fit decatts
There is a fair chance they will smoke, probably about a 30ish per cent chance IMO!
Mine didnt fit properly!
Had to heat the drivers side it and force it to fit, now my drivers side zorst hits the heatsheild with a thump if the engine shudders! Also they leak around the bolt holes so had to gub them up.
He says he will replace it if I send it back and he finds that it wrong
But that means the car will be off the road for 2 weeks and im trying to run it in at the moment!
Grrrr
May be an issue with the exhaust you are attaching the decat pipes to?
Nope, it was way out before the rear section was bolted on
Its was much more out before they bent it in the right direction
Still unsure wether the decat is wrong or the downpipe out by a few degrees
